Question about Epson Stylus Photo R220 InkJet Printer
220 wont pull paper into the printer
When attempting to print using the paper mode on the R220, I can't get the paper to pull through. I have to use my hand to try to gently guide the paper into the rollers, and most of the time, it doesn't work.
  • 4 more comments
  • Anonymous Nov 05, 2007
  • masterheff Dec 07, 2007
    paper will not go thru just bunches up
  • Quatrina Dec 12, 2007
    Yeah, it's really quite irritating and it's going to cause some major issues when I have to print on the back of these sheets tonight, I can tell.
  • Anonymous Dec 12, 2007
    I have same problem. Especially when feeding envelopes through.
    I miss the old switch that Epson used to have allowing you to switch from standard paper to heavy stock/envelope. I too have to try and push envelopes through, the rubber wheels don't seem to grab the stock.
  • rockola Dec 19, 2007
    i have two r220s. they both have the same problem. the paper will not load. have to gently pursade it by hand. very annoying.
  • CrazyMaryLee Dec 20, 2007
    My printer seems to only have this issue with card stock. Trouble is I use a decent amount of it. I also have to try and guide the paper through with my hand. Very annoying and it makes me sad. Quite some time ago my first printer was an Epson and I loved it. Never had a problem. This one, not so much.
    P.S. My cd printing tray doesn't work half the time either.
    Master:
  • 619 Answers
It need a technical job make carboard extend to guide ,clip it firmly and bye bye hand guided.
Posted on Dec 31, 2007
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Printer will not pull envelope into print area - worked fine in the past and still no problem with 8½ X 11 paper.
Problem feeding thick paper. Replace paper feeder. Or, add double tape bellow pick up rubbers at paper feeder. Check lubrication too.
Jun 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Stylus photo r220 not picking up 4by 6 inch photo paper
move the paper sideways (end on as apposed to flat) or select portrait printing instead of standard. good luck!
Mar 11, 2009 | Epson Stylus Photo R220 InkJet Printer
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper Will Not Load
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 10, 2008 | Epson Stylus Photo R220 InkJet Printer
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
Hi - have you tried giving the tray a little push; I had to do it with my R200; one minute it was fine the next I received the same message as you - Might work - brand
Sep 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Not printing on card
preciso do reset da r 220 por favor alguém me ajude um abraço
Aug 01, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
