Question about Digital Cameras
Optio M2D flash won't turn on
Help. The flash on my Pentax Optio M2D doesn't work even when I turn on the flash feature.
I remember hearing a soft pop the last time I tried to take a photo with the flash.
What could the possible solution be?
  • 88 Answers
SOURCE: Transferring photos from my Pentax optio S10 camera to my compute
Use the USB cord or get a card reader to download the images. You will have to install the software that comes with the camera otherwise the computer will not recognize your camera,
Posted on Jan 09, 2009
  • 126 Answers
SOURCE: pentax optio 430.
the focus assembly is not working . will have to replace lens assembly to make work correctly .
Posted on Apr 18, 2009
  • 16 Answers
SOURCE: Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Posted on Jul 23, 2009
  • 94039 Answers
SOURCE: How do I get the photos off my camera to my computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
There are also plenty of photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
Posted on Apr 19, 2010
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Posted on Aug 22, 2010
  • 356 Answers
SOURCE: My Pentax Optio W90 "locks up." When I turn it on,
Check to make sure that the capture button is not getting stuck in the down position.
Posted on Mar 03, 2011
0 characters
1 Points
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Mar 21, 2011 | Pentax Optio E10 Digital Camera
Why every time I take a picute on my pentax p70 appears on the screen: data being processed and tkaes about 5 to 10 seconds to get ready to the next one? What shall I do to stop it?
The camera does some digital noise reduction, to reduce the 'grain' effect when light is low. To avoid the delay (and seeing that message) take photos with more light - e.g. turn on the flash. This is a known annoyance with this camera - it would have been better to offer the option to turn this feature off, and de-noise the picture later on a computer; but it doesn't.
Aug 11, 2010 | Pentax Optio P70 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Pentax Optio S - lens cover rings popped off
I'd be most happy to share with you how I solved my problem with the Pentax Optio S. It took a bit of clever 'problem-solving' thought and inspection. After suddying the design of each piece and the working components of the exposed lens area, I was able to identify which sections worked together appropriately.
And, I think it appropriate at this time that I ask you to purchase one of my plans in order to receive the full benefit of what I learned from my skillful thinking and examination, and thereby successfully repaired my camera.
I look forward to hearing from you.
Jan 03, 2009 | Pentax Optio S Digital Camera
My Flash stopped working, but I don't understand the manual instructions.
To ensure the flash is functioning study the manual and check the LCD menu to such a feature as a flash on/off control.
Aug 12, 2007 | Pentax Optio S40 Digital Camera
Pentaxs50 turns on lense does not extend memory full displays on Lcd then it turns off.
throw it in the garbage and get a less expensive Samsung digimax s500 for less with better quality and features.. What a mistake in purchasing a Pentax. I wrote to Pentax for I had the same problem. Answer, send it in for repairs with a cost if it is not undaer warranty. Not even a hint as to what may be the problem from them! Pentax, No thanks!
Oct 22, 2006 | Pentax Optio S50 Digital Camera
Digital Cameras Logo
80 people viewed this question
Top Digital Cameras Experts
Are you a Digital Camera Expert? Answer questions, earn points and help others
