Question about Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC 24 pick up head wont spin
I press the brushes on/off switch and the little red button thing on the side fo the head itself (whatever thats supposed to do), but the head seems to only spin when it wants to.
I see lots of folks with the same proble here. Any ideas?
Thanks.
    Sniper:
  • 83 Answers
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Posted on Jul 30, 2009
The DC24 dies not have a belt drive. The roller brushes work on the vacuum air pressure. This is switched on and off using a micro switch next to the power switch. The grey button next to the red one sometimes sticks so it won't reach the micro switch underneath to start the brushes. I removed the surrounding plastic on mine using the three star shaped headed screws on the rear panel behind the power switch. I checked the micro switch by pressing it a few times and sprayed a little lubricant silicon grease around the moving switch parts. It took about 20 mins in all. The design could be better as it relies on a long thin plastic pointer to depress the micro switch. It it fails again I will bypass the switch by adding a wire loop between the two contacts of the micro switch. This will keep the brushes rotating whenever the power is on.
Posted on Dec 12, 2011
I had the same problem iside the foot there is a motor that spins the brush what happened with mine was the belt stretched and kept on slipping and went round when ever it felt like it.
Posted on Aug 23, 2009
How do I get the brush to spin on a Dyson DC 24. I have thoroughly cleaned everything and pressed the reset button.
Hi , if i am correct the brush bar is driven by a small electric motor inside the brush bar. It sounds as if the motor has gone or the small printed circuit board has a fault. You will have to get it checked.
Mar 05, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Where is the reset button on a DC24 ball?
Hi there, it's Jack at Dyson.
In most cases, DC24's reset button should be located in a red recess on the side of the cleaner head, as shown in the video guide below. It may help to use something like the eraser-end of a pencil to press the button - you should feel a click as it engages.
Some newer DC24 variants don't include a physical reset button, and instead the reset mechanism will activate when you turn off the vacuum, then turn it back on and recline it into the normal vacuuming position.
If you can't see a reset button on either side of the cleaner head, this may be the case with your machine. If you're unable to reset the cleaner head, please contact our experts directly. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 14, 2015 | Dyson DC24 All Floors Upright Cleaner...
Dyson dc 24 brush works intermittently
Broken wires in the side of the machine
Dec 27, 2013 | Dyson Vacuums
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
Can't release brush head on dyson dc24
I'm sorry to hear you're having difficulties with your DC24. The red button you're referring to is the brushbar motor reset button; the catch to release the brushbar is on the underside of the cleaner head.
To clean any threads or hair from the brushbar, please follow the steps shown in the video below.
I hope this helps - if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 18, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Jul 11, 2010 | Dyson DC25 All Floors Bagless Upright...
Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
Dyson Animal 17 - brush stopped turning
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin, press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
Jun 24, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The handle to a canvas bag got stuck in my DC 17 animal Dyson and now the brush won't turn.
Apr 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Ball DC24 Bagless Upright Vacuum Logo
10,000 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
