Question about Sony Video Game Consoles & Games
I have a game called d warp but they say dose not exsist
    Sergeant:
  • 321 Answers
Plz explain more whats the problem
Posted on Jun 22, 2009
What dose the sequencer do on a home furnace
On a call for heat, a heating element in the sequencer starts warming a small heating element which causes a small piece of bi-metal to warp. As it warps it pushes on relays which first light the burner and a short time later, start the fan.
Nov 21, 2013 | Heating & Cooling
Tip
The problem only exsist while playing block ops... i think its a problem with...
How to fix PlayStation 3 corrupted hard drive
If your PS3 will not fully load and you are getting a message that the hard drive is corrupted. Go through the options in recovery mode. The link below will help cover those options.
http://www.youtube.com/watch?v=yZWye1CLTVo
If you have gone through the recovery mode options then you may just need to do a full format of the hard drive or there is something wrong with the drive.
Note with a normal hard drive from time to time a sector will fail on a drive. Normally Windows will fix the this with on of the backup sectors on the drive but in the case of your console systems this may not repair the drive.
1. Next what you will need to do is remove your hard drive from your PS3. To do this you will need a small flat head screw driver to pop the hard drive cover off. You will see a tap on the right side to put the screw driver in.
2. Next you will want to remove the lock screw that holds the drive in place. Normally it is green.
3. Next lift up the lever and pull the drive back to the right into the open space. This will disengage the drive from the PS3.
If you are needing the steps to remove the hard drive from the PS3 Slim go to this link. How to remove the hard drive on a Playstation 3 Slim.
Note after you get the hard drive removed from the PS3 you do not have to remove the drive from the caddy that the drive is in.
4. Now you will need to connect the drive to your computers SATA hard drive port and powersupply. Note if your computer does not have a SATA connector and/or you have a manufactured computer like a Dell or HP you may not be able to connect your hard drive directly to the computer. They make USB external kits that will let you connect the drive externally via USB.
5. Next you will want to boot your and open My Computer. After my computer is open you will want right click and select format for the drive that is from the PS3. The format options should open up. You need to make sure that the "Quick Format" option is not check. Note be sure that before you click Start on the format that you are selecting the drive for the PS3.
Note if the Full Format hangs then this is a sign that there is actually a problem with the hard drive its self.
Also note if you have the drive connected to the internal connectors it will show up like a standard drive but if you have it connected externally it will show as a removable drive. If you do not see a extra drive letter you may need to assign one to the drive the links below will help you set a drive letter.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
6. After you format the drive you will want to put it back into the PS3. When you put it back in you will be prompted to format the PS3. The PS3 format will setup the drive for use with the PS3.
Note you may need to reload the firmware on the PS3. If you need to do this you can get the firmware and instructions to install it from this link.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
At this point you should be able to use your PS3 as normal. If you still have trouble then you most likely have a problem with the hard drive its self.
on Nov 12, 2010 | Video Game Consoles & Games
Cant get any responce from check email for identifacation code just a joke i will put my email address but ebay will tell me it dose not exsist but i use it day to day ha
I'm pretty sure at this point you made a typo. It's also possible you gave a work e-mail that's not not relevant to people outside your company.
Sep 08, 2011 | eBay Auctions
Pls help. using adobe photoshop free trial,has expierd need code or a way i can get my photos,as photoshop 3.2 dose not exsist any more
Download a trial of photoshop elements, however, unless you were working with .psd files, any image editor should be able to open the files if they are .jpeg or .tiff
Dec 30, 2010 | Computers & Internet
The disk is not going in we put the disk in a dose not go in
check your game disc for scratches and check ebay.com for a disc cleaner.........
or this is going to need a repair. call nintendo at 1-800-255-3700.
Dec 21, 2010 | Nintendo Wii Console
My ps3 wont play any games except for god of war 3, it is as if the other games do not exsist?
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Sony and see if the unit is still under warranty.
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Apr 03, 2009 | Ariens 34 In. Zoom Series Riding Mower
Zelda twilight princess: sky cannon
Well, you can use a cheat code to allow you to warp anytime by using a homebrew application called Ocarina, which is usually built into most backup loaders by default. Go to wiibrew.org or any other site that focuses on loading backups to figure out how to use it. You don't have to start all over if you can cheat. :)
Jan 19, 2009 | Nintendo The Legend of Zelda®: Twilight...
Multiplayer
it could be saying this because either they closed the match or there were the max players in it.
Oct 05, 2008 | Rockstar Games Grand Theft Auto IV for...
Video Game Consoles & Games Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
