Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
I know where the thermal fuse is, but I do not know how to check to see if is good! How do I do this
  • nikkicombs Jun 20, 2009
    Hey, it's a dishwasher, and I don't see any wires coming from this thing. It looks more like a circuit. Any suggestions. The dishwasher has no lights or anything coming on. Checked the power supply, the door switch, all appear good.
  • nikkicombs Jun 21, 2009
    I read things wrong daily. The model number is GU980SCGS2. I appreciate all the help you're providing. Also, I know that it has a motor that could be bad....how would I check to see if that is the case?
    President:
  • 1,136 Answers
Hi, You will need to test it for continuity. The fuse should test closed.
Another way to test this is, tape the two wires to the fuse together and plug the dryer back in. See if the dryer starts. If the dryer starts, the fuse will need replaces.
I hope this helps you.please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
  • Victor
    Victor Jun 20, 2009
    I am sorry I read it wrong. If you could get me a model#, I can look up the picture of this d/w. If this is a whirlpool make, there is a fuse attached to the board on most madels.
  • Victor
    Victor Jun 21, 2009
    #4 is the fuse
Kenmore dryer model #110.80754001 NOT HEATING
you checked the element so you know how to use a meter good,go in the back again,look at the duct that the lint filter goes into down low and to the right you'll see a white part with two wires going to it,that's the thermal fuse,pull at least one of the wires off and check for continuity,if you haven't cleaned out the dryer and vent line this usually pops,if the dryer can't move air from lint blocking the air flow the fuse will pop because the dryer is running to hot,if the fuse is good check the t-stats on the heater box for continuity.common things to go thermal fuse or t-stats on heater box,all has to do with dryer running to hot.thermal fuse is part WP3399849,you can go here to see all parts in machine
https://www.searspartsdirect.com/model-number/11080754001/0582/0152000.html?searchType=modelSearch&q=110.80754001&searchTerm=110.80754001
go here put model number in
Jan 25, 2018 | Kenmore Dryers
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
I have voltage to dryer, door switch checks good, start switch checks good, but dryer will not start. What can I check next?
Check the continuity of the thermal fuse located on the blower housing. This thermal fuse is wired in series with the motor and once blown, power to the motor is terminated and the dryer will not start. Also the power to the heating circuit is activated through the motor centrifugal switch. The dryer will therefore not heat once the motor cannot run.
Disconnect power then access the thermal fuse on blower housing.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
You can bypass the thermal fuse for troubleshooting purposes by disconnecting the wires and connecting them together. Insulate the connection properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if you need further advice but indicate the exact model number of the dryer.
Jan 28, 2011 | Kenmore 62622 Electric Dryer
Dryer drum works but does not heat. Everything else works. I have checked the fuse and I have made sure it is not on air dry.
THERMAL FUSES MAY BE THE CAUSE OF THIS In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element. Follow the diagram below to see how to check the continuity of the switch, and look closely at the switch to see a fairly close idea of what you are looking for, ok
OR it could be a thermostat.
Cycle and safety thermostats-read them with an ohm meter. Should show continuity .
or lastly, it might be
the Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Do not forget to rate this answer!!
Jan 24, 2011 | Frigidaire Electric Dryer
I have a whirlpool dryer and it does not start, i tried continuity on the fuse, the start switch, the lid switch and even the thermostats and all are good. i am also gettng good voltage.. i don't know if...
First thing to check is the Thermal fuse, See if its open using a meter
Second, check if you have 120 volts on both sides of the Thermal Fuse
If you do most likely its a bad motor
Nov 09, 2010 | Whirlpool LER4634J Electric Dryer
My dryer runs but has no heat. I have replaced the thermal fuse. I have checked the breaker, cleaned out the lint trap and checked the air flow which is good. I do not have a volt meter. Kenmore Electric...
Hello there :
There are severaol things that could cause this to happen
Things to check are :
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
I know that you have checked the thermal fuse so you dont have to worry about this.ok
Hope thatthis is very helpful
Best regards Michael
Dec 23, 2009 | Kenmore Dryers
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool dryer will not heat
check for continuity at the heater element if thats good check the thermal fuse on the element housing at the top jump it out and if the heat comes on replace the thermal fuse let me know how you make out
Aug 05, 2008 | Dryers
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
328 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
