Question about Acer Aspire 3610 Notebook
Computer will not turn on.
Battery showing critically low. Plugged adapter in and still will not stay turned on. Tried taking out and plugged in and would not turn on at all.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    what happens if you take the battery out and only hook up the ac adaptor to the laptop does it stay on at least?
    Sergeant:
    Champion:
  • 253 Answers
U should get your battery changed and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My computer won't turn on at all, the green light comes on but only a black screen shows. When it was plugged in to power the light wasn't showing that it was charging so took out the battery and then...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Not turning on
My unit was totally dead. I just kept it plugged into my computer for about 12 hours. I downloaded the newest software from Garmin. When I unplugged it from my computer, the battery seemed to drain quick, but once I plugged it into the card adapter in the car... everything seems to be running great now.
Oct 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Dell Inspiron E1505 shorting out adapter
I would replace the battery if you had for some time. Over time charging a battery will slowly not take a charge. If you tried two adapters, about the only thing is left is the battery.
Aug 18, 2009 | Dell Computers & Internet
Phone keeps blinking, will not stay on
This may due to the moisture accumulated inside the phone. Kindly open the phone casing, take out the battery and let it sit on room temperature.
have you tried turning the phone on with its adapter plugged? it may also be caused by a low power source. your battery might need charging.
otherwise, do consider replacing your battery.
Jan 15, 2009 | Samsung SGH-E900 Cellular Phone
Computer start-up
ok...try this without battery, only with ac power pack plugged in.
got backup?
Feb 11, 2008 | HP Compaq Presario V2000 Notebook
MY Laptop battery , Adapter or Motherboard
Did you buy an adapter that matches the same voltage and amperage values as your original?
Jan 11, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3610 Notebook Logo
350 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
