Question about Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
Kenmore dryer, 600 series, runs but does not heat.Just bought used, looks pretty new. Runs fine just does not get hot. Checked for lint, pretty clean.
  • 57 Answers
Check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Posted on Jun 20, 2009
Kenmore 600 series electric dryer runs but wont heat
There are several things that could cause this problem but the most common can be can be checked by following this guide:
Electric Dryer Runs But Dont Heat
Jan 11, 2014 | Kenmore 600 7962 Dryer
Dryer wont heat. cleaned exhaust duct still problem exsists. Model 60 series kenmore gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 600 6965 Electric Dryer
Kenmore 600 series gas dryer not heating
heatman101
Jun 26, 2011 | Kenmore 600 7965 Dryer
I have a kenmore 600 series dryer that runs but does not heat up. I assume that the heating element is bad. Would that be a good assumption?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Dryers
I have a 600 series kenmore dryer and the heating element turns on when i set the timer and before i push the start button
Sorry to read about your problem, I hope this helps you out.
sounds like your start button is stuck on...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Kenmore 600 6965 Electric Dryer
I have an kenmore 600 series clothes dryer. It's about 1.5 years old. The dryer tumbles. gas and electric are on but no heat.
It is most likely the element if it is an electric dryer. If it is a gas dryer be sure that the pilot light is on for the gas at the valve.Also this machine is most likely under warranty so check it out.
I am 90 % sure that is an electric dryer so I would check to see that one of your breakers for the dryer are not tripped as one can run the dryer but it needs two to get the heat running as it runs on 220 volt.
Oct 06, 2010 | Dryers
Our dryer was running fine and now it wont turn on.
It could be the timer or a safety switch that keeps it from over heating.Sears used to sell a home owner repair manual.You can call Sears Parts Central or go to the web site and give them the model number and see if they have the manual. It is a pretty good easy to follow manual with a good trouble shooting section.
Aug 10, 2010 | Kenmore 600 6965 Electric Dryer
DRYER RUNS, BUT WILL NOT HEAT
Do you have fuses or breaker? If you have fuses one fuse may be burnt out.
Jul 12, 2010 | Kenmore 62822 Electric Dryer
Dryers Logo
823 people viewed this question
Top Dryers Experts
Marvin
Marvin
