Back to:
Tags:
Phones
Generic problem for all Phones
Line in use message (by 4 users)
posted by melch4 on Nov 02, 2007
I have a Panasonic 2.4 GHz Digital Cordless Answering System model # KY-TG2386B. I have had it for a couple months now and all of a sudden I cannot get a dial tone and I have alot of static, and it says that the line is in use. I do not have any other phones in the house, just my DSL, and Satellite dish for TV. Any help would be appreciated. My manual does not tell what to check for in the case....... faith53@verizon.net
Thank you
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Sep 02, 2008
No dial tone, display says "line in use".
It started out with static on the line. Then suddenly we had no dial tone into base or to the two hands free. Have disconnected/reconnected both batteries, disconnected phonelines and power, but no solution.
Comment by Guest, posted on Jun 18, 2008
it keeps saying that the phone is in use and its not i only have 2 phones and both of then are close and i don't have a tone and i can't call nobody or recive calls
Comment by salpaublo, posted on Feb 24, 2008
I have a Panasonic KX-TG5653 phone and it worked great until we changed service supplier. I was inactive for about 2 weeks and then we changed from AT&T to cable. It hasn't worked since we switched to cable. I doesn't even work at my neighbors house - so the KX-TG5653 phone died for some reason. The phone registers "LINE IN USE" and has a busy signal. The manual does not offer direction for this type of problem.
Does any one have suggestions ... or are we just out a nice phone?
Solution #1
posted on Jan 23, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
We had the same problem occur even though an older model touch tone phone was working using another jack in the basement. Unplugged the Panasonic from power and telephone jack, and took it to that jack.
When it worked, came back to the original jack, disconnected/reconnected it from the wall, disconnected and reconnected the DSL filter from the line, plugged the Panasonic back into the telephone line and power, and everything started working again.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Line in use message:
I don't want to Accept this solution
Solution #2
posted on Dec 29, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I had a similar problem and from the menu and Initial settings I switched the line mode from A to B and the In Use button disappeared.
Bernard
Thank You!
Can you Help with these Phones problems?
Phones
in use light blinks on @ off all the time
Phones
Well a tech came to my home and never came back and left...
Phones
suddenly my uniden phone answering service has stopped...
Phones
My daughter is traveling in Europe. She has tried to...
Phones
My daughter is travelling i Europe. She bought an Orange...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
