Question about Samsung Q1 Tablet PC
Relating to ram
Hello, actually i m using 128 ram in my computer . in moterboard there is two slot. before i was using 256 ram (128+128) in both slot . my computer is p3 . now it is working in 128 ram . now my quary is that it will b ok to use hiher capacity ram(like 256,512,). can i go with 128+your specification . or should i use single one like 512. suggest me which option will b suitable for my computer ?if there is more than 512 give option 2 me . and what will b benfit for that .with (128+128)my computer is more faster than 128.but sometimes it hangs up .pls suggest solution .
  • 2,229 Answers
I am not sure what motherboard you have, but I would suspect that your computer will take at least 2 sticks of 512 MB each.
You didn't say what operating system you are using. If you are using Windows 98, 128 MB is fine. If you are using Windows XP, you should have at least 10x that, or 1GB to run correctly.
You really do need to know how much memory your computer will support, so you can go on the manufacturer's site and look it up or use the manual that came with the computer, if you still have it.
Posted on Jun 20, 2009
At boot up it stops and gives me an "Extended Ram Module Fail" It recognizes the CD/DVD Player and a new harddrive with nothing on it.
see
http://www.computerhope.com/issues/ch000394.htm
This is most likely a RAM issue but it may be that your RAM slots on your motherboard have become defective. If the latter, you will need to replace the motherboard, which may mean buying a new computer if a motherboard cannot be found at a reasonable price (try ebay as well Panasonic and other computer dealers)
However you should start by finding out what RAM is in your computer which means opening it if it won't start.
see the reference manual which can be downloaded at http://www.panasonic.com/business/toughbook/computer-support-download-manuals.asp Go to p119 - there you will find a slightly more informative description of what the problem is likely to be (RAM module). I don't know where the RAM modules are situated in your particular model of CF29, you will need to find out. Remove all of them. (see ref manual on how to do this - it looks like the standard method for laptops). Replace one of them in the approved fashion: ensure that it fits well: usually it is easy to tell when this has happened - see other guides for upgrading laptop RAM modules or videos (you tube has many) for this stage if you do not understand the Panasonic ref manual - I found the IBM T40series guide at www.lenovo,com very easy to understand. Now try starting the computer. If it gives the same error, remove and the RAM module and try again. If this doesn't work try the other RAM slot if your computer has one with the same memory module. If that doesn't work repeat the process with the other RAM module [if the computer had one]. In this fashion you should be able to determine whether and which RAM module is defective or if it is one of the slots on the motherboard. If there is only one module and slot, you will need to try reinserting the RAM and if that doesn't work using another known good stick of RAM of the correct type (not all RAM sticks of seemingly the correct spec, will work though: best use a reputable brand). This will tell you whether it's likely to be the original RAM or the motherboard, or just that the RAM had become improperly seated.
While carrying these operations the computer should be powered down and have the battery removed. Observe anti static precautions and do not force anything.
Good luck
17.January.2015
Jan 16, 2015 | Panasonic Toughbook CF29 Pentium Mobile...
How can I ad an additional stick of RAM (2 GB) on my TC4400 tablet? Where the additional slot is? I didn't find it. Thank you, Benjamin
There should be a cover behind the laptop, unscrew these tiny screws and the back cover should open. Then you want to located where the rams are at. In some case the ram slot is already being used by the original rams and you need to take these out to install the new ram. Before hand, make sure your laptop support the correct type of the ram, in your case it will support ddr2 sdram up to 4gb. So pretty much once you locate the ram slot after opening the back panel... then just install it.
Jan 14, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Hi, i bought sdram for a laptop online, i scanned the computer first to check what i needed. i got the ram through, fitted it and now the computer just beeps and wont start, please help
If the RAM is not properly seated in the slot, this can occur. Check the RAM alignment and make sure they are pushed all the way into the RAM slot. Be careful because it should not take much force to push them in, and the notch in the stick will line up with the slot on the laptop.
Could be the RAM is bad or is the wrong type for you machine, which you can test using a boot disk and a program like Memtest86. http://www.memtest86.com/download.html
Also, some laptops will require you to confirm the new amount of RAM in the system BIOS so you may need to go in there after it's properly seated.
Mar 17, 2010 | Tablets & eReaders
Max ram ??? pls help.THX
This laptop can support up to 1 GB of PC13 type of RAM, this unit usually came with only 256 MB of RAM so you have an option to put the maximum amount of RAM for it which is 1 GB.
Jan 06, 2010 | Toshiba Portege 3500 Tablet PC
Were is the ram situated
The Compaq Tablet PC TC1000? (Marketing Part Number D 70045-236)
Turn the laptop over, you're looking at the bottom. Battery Compartment is to the Right.
To the left of the battery compartment is the Memory Compartment. (The parting line for the memory compartment door, starts to the left of the battery release button)
The Memory Compartment is rectangular in shape. The right lower corner has a half U shaped cutout. (Next to the battery release button)
At the top of this panel, or door, are two Philips head screws. These are removed. The panel is then lifted up at the side the screws are on, SLIGHTLY, then slid forward. (Forward. Away from you)
(There are two plastic tabs at the end towards you. They slide into the body of the laptop, and if the panel is lifted Straight up, these small plastic tabs could break off)
This is HP Support, and the download page for Manuals, for the Compaq TC1000
(HP and Compaq are one, and the same entity now)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=307008
I would like you to download the Hardware Guide for this tablet PC. It explains about the hardware, and also shows how to install ram memory.
(Copy and paste the above link to your address bar, press the Enter key)
Under the - General Reference - section heading.
Click on - Compaq Table PC TC1000
Series Hardware Guide
(Second one down)
This is a PDF file. Your computer has Adobe Reader on it, which uses PDF files.
I advise letting it download all the way before looking through it, or you may break the download connection.
Page 128 starts with telling you how much is the Maximum Amount of ram memory.
(512MB)
Tells you that there is only 1 Ram slot.
The next page tells, and shows you how to open the Memory Compartment door, then details how to remove,and install ram memory.
Nov 22, 2009 | Compaq D70045-236 Tablet PC
Can't find ram slot!
There are laptops that do not have two slots for RAM. the EEE Pc's for example only have one slot.
Nov 18, 2009 | Acer TravelMate C302XMi Tablet PC
How to install RAM?
You can get detailed description of how to install the ram in the below link
http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | Toshiba Tecra M7 Tablet PC
I am using HP Laptop compeq presario c301tu when on the notebook the power led always blinking but here no disply
Dear client! You should check your RAM change slot use other slot for RAM if you have. It is very possible your problem will be solved. If problem remaining same you should your VGA it might be possible that it could be out of order and it will being not worked. If your laptop does not give any beep it could be possible your motherboard problem presist. But I assure that RAM will be out of order or RAM's slot fault so first of all you check your RAM or RAM's slot.
Thank You
Jul 25, 2009 | Tablets & eReaders
Need a memory module for toughbook cf-18bhazxft
You can go to a website like kingston.com; crucial.com; tigerdirect.com; newegg.com & use their memory finders to find out what type of RAM your computer uses & what they have available for purchase. Hope this helps & please rate this solution as fixya. Thanks.
Feb 03, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Memory reading
please check RAM its 256 or 512. pick up RAM & change the memory slot.
Sep 17, 2008 | Compaq tc1000 Tablet PC
Samsung Q1 Tablet PC Logo
81 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
