Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
External Hard Drive will not show up. Tells me to format it.
How can I retrieve my data in my portable hard disk. I use wd320 gb (WD3200ME-01 USB DEVICE). I had 200 Gigs of video on but tnow the computer wont recognize it. It tells me I need to format the drive? Any way to retrieve the info?
  • Amruth Louis May 11, 2010
    Did you try the drive on other computers?
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Posted on Jun 23, 2009
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
I got a transcend 320 GB external drive with data on it but windows 7 says I need to format it before using it. I know it is formated in FAT but that all I can see. EASEUS said there was a problem but...
Make a linux boot disk. Boot your computer with this disk. Retrieve all data to other disk. than reboot windows 7 and format disk.
LinuxMint life cd, does not install.
http://www.linuxmint.com/download.php
Feb 13, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have a toshiba ez external hard drive and I hate it... just want to clear it and send it back. but can't figure out how to do that
Just open it and highlight everything then rt click and pick delete,
and you should go to my computer, and rt click on the drive letter
and pick format, and format the drive.
If you have personal info on it, get a program called boot and nuke,
its free for the once write, you boot from the disk you make
and it will erase so that most people can not retrieve data from it..
Feb 05, 2010 | Toshiba 120GB USB 2.0 Portable External...
Disk does not show in explorer window
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 11, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My wd3200me was working now not
Try connecting to a different USB port on your computer.
Try a different USB cable.
Try connecting it to a different computer.
If it still does not work, either:
* the USB-to-disk-drive adapter has failed
* the disk-drive has failed
If the former, open the case, and remove the disk-drive,
and temporarily connect this "internal" disk-drive as a "slave" disk-drive into any desktop computer, and copy all the files. Or, remove the disk-drive, buy a new "empty" external-adapter, and install your disk-drive into the new case.
If all else fails, search online for "Data Recovery Services".
These type of companies are expensive, but they can "recover" files from almost any hard-drive that has "failed".
Jan 02, 2010 | Western Digital Elements powered by WD 320...
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
Aug 11, 2009 | Western Digital WD Passport 250GB Portable...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
Info Lost/Portable not recoginize
Assuming you've already tried using it on another PC or Mac (as appropriate) with any needed software installed, and that didn't work, your next DIY step is to remove it from the container.
If you can remove it (most drive makers do not publish the instructions to disassemble their equipment), you can hook the drive up inside most PC (not laptop) cases directly (if they have the required IDE or SATA connection), or take it to your local PC store for a quick test.
As a last resort, you can sent it to a "disk or drive recovery" company to get some or all of your data back if it hasn't been lost to a surface defect on the disk. This is usually a fairly expensive option.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
WD3200ME-01 Passport size diskspace problem
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Jul 03, 2008 | Western Digital 320GB MyBook External USB...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
1,093 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
