Question about Zenith L15V26 15.1 in. HDTV-Ready LCD Television
Zenith L15V26C no video problems
I have a zenith L15V26C , the sound comes on when I connect a audio source to it and can hear the static when I connect it to a antenna , but thee is no video , only a white screen wit a blue spot around the bottom of the screen. This happens when I try to connect it to a compute, antenna using the video inputs.
4 Suggested Answers
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
  • 267 Answers
SOURCE: Zenith L27W46 video source switcher not working
IF YOU PUSH ON THE SCREEN LIGHTLY AND SEE DISCOLORATION, THIS MEANS THE PANEL IS ON AND YOU PROBABLY NEED THE MAIN BOARD. IF SCREEN DOES NOT DISCOLOR YOU HAVE A PANEL, INVERTER BOARD OR POWER SUPPLY ISSUE.
Posted on Mar 20, 2009
taran_2005
  • 10515 Answers
SOURCE: have zenith plasma tv
There are a couple of different things that could cause this problem, the first is the power supply, and the second the main board. Also either sustain or scan driver board can cause this problem. To know exactly what board is the cause, you need to have electronic repair experience, and test equipment. If you have this let me know and I will assist you in the troubleshooting of this tv. Otherwise you will need a repairman at this point. You can expect a bill of anywhere between $200-$500, this is a good average, however it could be more or less.
I am sorry I don't have a quick fix or easy answer for you on this one, please let me know if you have the skills and tools and I will be happy to assist you. Also please let me know if there is anything else I can do for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2010
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Left front and left rear speakers do not work, they produce some sound but mostly static. The "phono" rca jacks also do not work.
First off make sure that the cables you are using are functional. Also,check and verify the locations of the connections. You need an audio output from your source to an audio input at your receiver. If you run a video output from your source to an auido input on your receiver that will create strange sounds
Jan 07, 2011 | JVC RX-318 Receiver
I am connected to the TV from the sound system. Of my six speakers connected, I can only get sound from the SW, and the front L & R speakers. No sound is coming out of the Center or Rear L & R. ...
You don't say HOW the 'TV' audio is carried to the RT2500? TV's are usually the end of the chain, not a link in it. For multichannel audio you need a multichannel digital source. Is that the TV or would it be the cable/sat box? Try running a digital audio cable from one of those to the RCA.
Dec 27, 2010 | RCA RT2500 System
Can hear sound but no picture
You didn't mention what the source was or how it was connected or if you were using analog or digital connections.
It appears that the device (cable box, maybe??) is assigned to different inputs for audio and video.
The solution should be really simple.
Kind of odd for this to just "happen", but it might have something to do with static electricity or a small power surge. Your first remedy should be to unplug the H/K receiver for 30 seconds and plug it back in. This should reset any logic hiccup.
The AVR's manual will show you how to assign video inputs and audio inputs to specific devices. You'll do this differently, depending on what cables you are using and how you have set up the source device, but the instructions do tell you how to make this work.
Basically, you'll need to know what button on the AVR you want to use to select this source. Then in the AVR's menu, you'll need to tell the receiver which of its inputs should be selected when that source button is pressed. Look closely at the back of the receiver and see where you have connected the cables. Your solution might be to simply move the audio and or video cables on the back of the receiver to jacks with the same labels!
For instance, if the video cables are connected to the receiver's video-1 jacks and the audio cables are connected to its video-2 jacks, just make them both the same.
Jul 24, 2010 | Harman Kardon AVR 240 Receiver
Just trying to hook up a new DVD player to my 1998 Zenith TV?
Connect your video source [cable, satellite, etc] to your dvd and connect your dvd to your tv. Get back if you still have a problem.
Jun 19, 2009 | Zenith A25A23W 25" TV
I want help to fix my headset whith microthone.
You better use analog multitester so you can hear a static sound coming from the headseat when you going to test.If happen you can't hear a static sound the common problem is the wire is breaks or cuts,then find where the cuts is and join it so it's works again.
Hope it may helps you;
Regards;
VOTIT
Nov 28, 2008 | Audio Players & Recorders
UA-4FX Very static-like feedback / interference
its electromagnetic interference from power source of laptop. you can get an audio connection wire that reduces this
Sep 19, 2008 | Edirol UA-4FX External Sound System
ZENITH TV, no picture
Sounds like the vertical output IC causing the CRTs to blank you would still have audio and on screen display. Try resoldering the vertical output IC.Thats a common problem
Mar 19, 2008 | Televison & Video
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Zenith lcd-tv Monitor model number L15V26C
I need an ac adapter for my Zenith L15V26C LCD TV.
Feb 12, 2007 | Zenith L15V26 15.1 in. HDTV-Ready LCD...
Zenith L15V26 15.1 in. HDTV-Ready LCD Television Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
