Question about Rainbow Vacuums
Rainbow model e2 will not turn on! - Rainbow Vacuums
    Problem Solver:
  • 11 Answers
Is the basin in place? There is a safety feature that will not allow the rainbow to turn on unless ontop of the basin. Also there should be a tap ontop of the basin that lets the rainbow know it is in place, make sure it is not broken off. If so, you will need to get a new basin. If purchased through a independent dealer, it may be under warranty. Less than 4 years old, everything is covered in the warranty.
Posted on Aug 14, 2009
My rainbow vacuum cleaner is not working - the air filter part is working fine but when I switch it to vacuum it doesn't start it does nothing . what could this be ? It's the latest model e2 black
If it works on slow but not on high you probably have a bad PC board. The E2 is prone to board failures. take it to you local vac shop fro assessment.
Jun 10, 2017 | Rainbow Vacuums
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow E2 will run on High speed,but not the low speed.it's as if no power is getting to it,when.you try to switch it on low,but works fine on high
This could be one of two problems. It could be your switch is broken, preventing it from going to low speed. Try clicking it, does it still make a distinctive click sound, does it feel loose? If so it may be your switch: Rainbow e2 power switch
Otherwise if may be your computer in your E2 is starting to go bad. Often times if Rainbow stops going into one of the speeds it is due to a computer going bad. This is an expensive part and repair, so you should probably take it in and make sure it is the computer. Rainbow E2 controller 120v
800-775-6586
GoodVac com
Feb 13, 2015 | Rainbow Vacuums
Hi! if i purchase a rainbow vacuum on the net will i regret it?
Can't speak for others, but I sell rainbows on ebay, SE series and E2 models, when I get them in. My units are disassembled, cleaned, inspected and tested to insure quality. My write-ups include good and bad about the unit so the buyer gets NO surprises. They normally sell for around $325.00 (E2 model). The best thing to do is check the sellers rating and feedback for a good score. My score is 100% with all positive feedback. So I know there is at least one place to buy one without concern or regret. I usually list one or two a month: vacmantwo is my ebay member ID. Email address is,
bulu_one@copper.net
SE model will run about $150.00 plus $45.00 s&h
E2 model is about $325.00 plus $45.00 s&h
Prices depend on condition of unit. But I won't sell a unit that is in questionable condition. The outside usually has cosmetic issues, minor scuffing or blemishes, but does not affect the operation of the performance.
Nov 09, 2010 | Rainbow E series Canister Wet/Dry Vacuum
No power
You must have a late model 2006 or newer E2 two speed Rainbow vacuum that has the white foam padding in the canister, to dampen the sound of the motor, and has a red light on the computer board.
I hate to tell you, but your computer is most likely the problem, and is out on your E2 two speed vacuum.
The only solution is to get a new computer for it.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other vacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
I could supply you with another canister, if you are interested.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 20, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Jan 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
E2 gold series - makes loud noise on start up
That is normal. All E2 two speed Rainbows make that sound. It is because it has a brushless motor that the computer is controling, and the computer is controling everything. The motor rotor has no coils on it on the rotor, which is very small and light, and the computer gives it a small power boost when you first turn on, then increases the power until ir reaches full speed.
Thank you,
Ralph
Jan 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
There is a flashing red light on my rainbow e2 machine?
There is a flashing red light on my rainbow e2 and little smells bad
Dec 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
254 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
