DCL lcd turned blue and I do not know how to return to a screen that is much lighter
I do not know what fixed the problem exactly. I tried the old and often good solution of shutting down. It worked and I no longer have a dark blue screen. Restart would not solve the problem. ???
Thank you for the offer but I do not need it at this time. I will try your service when I have a problem in the future. ****
Posted on Jun 21, 2009
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
Replace Inverter Board ? LCD Monitor
That board will be almost impossible to find replacing the capacitors will usually solve the issue in most cases especially if you see swelled caps.
Dec 22, 2012 | Sceptre DCL20A 20 in. LCD TV
No power to dcl linl 94 camry
check the cig lighter fuse. the data link connector is powered by a fuse that is "hot at all times".
Jun 19, 2012 | 1994 Toyota Camry
Do not know how to change settings
My screen information is too large to read. When I try to change settings, I am unable to see the "OK" or "APPLY" buttons at the bottom of the page. How can I adjust my screen so that I am make changes.
Dec 30, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Aug 17, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
SCEPTRE DCLCD 20" MONITOR
plug it out and take for repair from technician or if you are a technician . there is problem in the main board where power comes in.
Apr 18, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Settings for dcl lcd monitor
Your laptop resolution is greater than the external monitor can handle. From your laptop, try changing the screen resolution to 800x600, if it works, up the ante to 1024x768. You can bring it up again until you find a comfortable screen resolution. You will eventually stop to a point when your external monitor displays about 80% of the laptop screen. That is, back to your original problem. But you get the idea. Cheers!
Mar 27, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Pin stripe screen
your video section video amp. ic dry solder.
Feb 29, 2008 | Microsoft DCL 9A+ 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
