Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire iwash smells like rotten eggs Wwhen what is pumped out
We do not live in the counrty, so it is not the water. i have used the tide cleaner. i was wondering if anyone knows if there is a filter or a hose that might be cloged. thanks
  • 111 Answers
No thats because of the detergent taht you been using , inside of the drum is full of detergent residue and its rotten
Posted on Jun 20, 2009
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
Ran good replace temp censor under intakemanifold checked everything 3times or more
IF YOUR GETTING A ROTTEN EGG SMELL IN THERE & HAVE A COOLING SYSTEM AND WINDING SOUND IT MAY BE A DIFFERENT ISSUE.EDUCATED GUESS?! IT COULD BE ANTIFREEZE LEEKING ONTO A BELT CAUSING A WINDING NOISE & A NASTY SMELL! LEAKING HEATER CORES SMELL LIKE ROTTEN EGGS BUT WATER PUMPS/ BAD & WET BELTS/PS PUMPS/ IDLERS/BEARINGS, ECT CAUSE WINDINGS MAY BE A COMBO OF PROBS TOO. GOOD LUCK FRANK M
Feb 15, 2016 | 1996 Subaru Legacy
Rotten egg odor inside washing machine when not in use. Want smell to stop.
Try running a cycle with a few cups of bleach. Or a few cups of vinegar. Let it set for a while. Should help
Oct 07, 2015 | Washing Machines
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
Mold front load washer
Sometimes you have to get a cleaner for that kind of machine Tide makes one or you can just bleach. First drain all the water out of it. There will be a little door at the bottom on the front with a hose in it use a bucket and drain it. Then run it through a cycle with bleach or that Tide Cleaner. Bleach works better. I always leave the door open when I am not using the machine. Hope it works
Feb 15, 2012 | Washing Machines
Dark particles all over clothes once washed. I cleaned the washer, ran a tide washer cleaner through, checked and cleaned the screen filters that hot and cold hoses pump water through. Is there anything...
sounds like you may need to check your hot water heater for deterioration. since you have done all that you need to check your water supply. a water heater can deteriorate on the inside for a time before you will notice it. good luck
Sep 06, 2011 | GE Profile WPRE6100G Top Load Washer
My hose is collapsing when i use my pool cleaner
the filter is clogged up which needs to be cleaned
I don't know if you you have a sand filter or an earth filter system but get it cleaned to operate correctly
Jul 07, 2011 | Hayward Pool & Spa
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
There is a smell like rotten eggs in the washer.
If you have used a non HE detergent in your washer this smell will occur often. Even using HE detergents over a period of 1 year since new they can get this odor. There are products on the market like Affresh: http://www.affresh.com/#/home or Tide washing machine cleaner: http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx?ms=true (select info)
What you can do is use a full cup of bleach and 1/4 cup powdered Dawn dish washing soap in your washer with some non greasy rags. Dump it straight into the tub (not via the dispenser) and run a HOT wash. You can also add a squeeze of lemon at the same time or lemon concentrate. If it has been a long time since a machine cleaning cycle you may have to do this 2 times. It is recommended you perform a machine cleaning cycle at least every 90 days.
Any feedback via a response here of your success or failure to get rid of the bad smell would be greatly appreciated.
Thanks for using FixYa.
Kelly
Jun 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
304 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
