Question about LG L1932TQ LCD Monitor
L1932TQ monitor flashes on, then blacks out
I had a couple of brown outs recently and the system was on, I thought I had my monitor plugged into the UPS but I did not. When I went to turn on the monitor I get a quick flash of the screen and then the monitor goes black, if I click the monitor off then on I get another quick screen flash then black again.
    Problem Solver:
  • 13 Answers
I would try connecting it to another computer or Laptop if you can to see if the problem is the same. You might also try disconnecting it from you computer and turning it on, it should “banner”(show a logo and or a no signal message). If it behaves the same way just a quick flash…. Sounds like its toast.
Posted on Jun 20, 2009
Overload indicator light stays red & continuous tone ups 1100
Take the battery out and see if it does the same thing when you turn it on.
Feb 06, 2013 | APC Back-UPS Pro 1100 (BP1100) UPS System
I hit the button to turn it on it will stay on for awhile and then it will start beeping really loudly an shut off
With your UPS turned off, unplug your PC and all other devices from the unit. Then turn the UPS on. If it still beeps and shuts off your UPS internal battery may need to be replaced or you have an internal UPS failure. Look for a red "battery alarm" light on the front of your UPS.
If the UPS does not shut down with all devices disconnected from it, Power off your monitor and look on the back of the monitor for a label which will tell you the amount of power it requires (probably 100 watts or less). Plug the monitor's AC power cord into your UPS and turn on your PC and monitor. With the UPS plugged into the AC line you are not using the internal battery and the UPS should remain on and your monitor should be working. If it shuts down you have an internal problem with the UPS.
Now unplug your UPS from the AC line (simulating a power failure) Your UPS is rated at 350 watts. Accordingly it should easily support the 100 watt load of your monitor. If the UPS continues to provide power to the monitor for 1 or 2 minutes down it's an indication that it's working properly and the COMBINED LOAD of your monitor. PC etc. when plugged into the UPS is exceeding the 350 watt capacity of the UPS. You will have to disconnect 1 or more devices from the UPS.
NOTE: Never plug a laser printer into an UPS.
If the UPS immeadiately shuts down after disconnecting it from the AC line with only the monitor plugged into it you have a bad battery.
If you found this information to be helpful to you please return to the FixYa website and rate me.
Regards,
Yavacotech
Dec 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
I have a CyberPower 725SL UPS. Shortly after turning it on, it will beep as if AC power was lost and the green light goes out. I checked the battery and it's good. I'm assuming something went bad with...
Couple different items to check.
  • Try letting the unit set ideal for overnight charging the battery. Do not even turn the unit on.
  • Replace the battery.
If you turn the unit on when the battery is plugged in and does not keep a charge you can almost be sure it is the battery or the charging circuit not maintaining the battery.
Nov 11, 2010 | CyberPower 725SL UPS System
I want to connect a UPs to my computer and I don't which cable goes to a system unit or the monitor.Please show me the clip
shut down the comp and the ups
unplug the cable from the comp and plug it in to the ups i/p
take the iec male to female cable that came with the ups and plug male into ups o/p and then female into your comp
turn on ups then turn on comp
thats it
hope this helps
thanks for using FixYa
Sep 19, 2010 | Belkin (F6C800-UNV-PL) UPS System
PULSAR 220F MINIMUM MILEAGE HOW PLZ TELL
If you are talking about a used UPS, i would not bother with a used unit.
I find if they are used 24hrs a day, when the electricity is tripped and the ups kicks in, they only last a couple of minutes.
I would plug just the pc and monitor into the UPS sockets, and plug everything else into the ordinary sockets. You will get alot longer out of the battery
Sep 04, 2010 | MGE UPS Pulsar EXtreme 2200 C - UPS (...
Hi. I returned from vacation and turned on my power strip and monitor, tried to start my emachine t5026 computer and got nothing. the power light on the back of the power supply is off. If I unplug or...
Your Power supply is most likely dead.
A power strip is not sufficient protection against black outs, brown outs, power surges and other electrical interruptions that occur in the house. Many PC components are very sensitive to fluctuations in power and power supplies often are among the first casualties when a serious problem occurs.
To protect yourself against these common power issues you should invest in an Uninterruptible Power Supply or UPS. A UPS is basically a battery backup that will provide power when brown-outs or black-outs occur and will protect the delicate electronics in your PC. You can purchase them at most stores that sell computers and components.
Nov 10, 2009 | E-Machines Emachine T5026 power supply **...
Battery Backup/Surge Protector Question
Considering the low draw of power you intend for the UPS it will work well. I have two monitors on a strip plugged into UPS along with desktop, routers and modems, UPS handles all well, it's just shortens battery backup times. Have had to power down from outages several times without any probs.
Jan 30, 2009 | APC Back-UPS RS Battery Backup (apw...
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
you can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Dec 03, 2008 | Minuteman Office Plus 500 UPS System
Battery/Surge outlets not working...
Sounds like the UPS battery is bad, or the circuit break on it has gone. Is there a reset button on the UPS? Do you have the program that came with the UPS to check the battery status, those programs typically let you run a test on it also.
Jan 29, 2008 | CyberPower OfficePower 825AVR UPS System
LG L1932TQ LCD Monitor Logo
244 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
