Question about Uniden TRU 4485-2 Cordless Phone (TRU4485-2)
No caller id or rocket dial on second handset
TRU4485-2; 2.4ghz. Second handset (HS2) does not show caller id numbers or allow entry for rocket dial. Get a series of beeps when trying to access CID or Rocket Dial buttons on handset. Solution?
We wanted to find out if you still need a solution for the Uniden TRU 4485-2 Cordless Phone (TRU4485-2) Problem you posted on FixYa yesterday.
In case you do, we'd like to offer you our Premium Assistance Plan
By using this plan, your problem will be addressed by a group of Elite Experts who can provide you with professional assistance and often solve your problem.
Click here for more information about this plan.
If you already solved this problem, Click here to tell us how you did it.
Regards,
The FixYa Team
__________________
To FixYa Team
Fixed it myself. Too bad you have to pay to get assistance from the FixYa Team.
Posted on Jun 22, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do i forward my phone calls
HOPE THIS HELPS:
Call Forward • The first handset (HS1) can forward an external call to another handset (HS2, HS3, or HS4) by pressing and holding the INTERCOM key. After entering the handset number to which you want to forward the call, HS1 will display CALL FORWARDED. • To answer the call, another system handset can press PHONE, SPEAKER or any dial pad keys.
NOTE: If the other HS2 does not respond within 30 seconds, the external call will be returned to HS1 and its display will show CALL BACK. If the returned call is not answered within 30 seconds, the external call will end automatically
THE MANUAL CAN BE FOUND HERE: http://dl.owneriq.net/c/c72cee7d-bd52-42c1-b9fa-2ee5ccc500af.pdf
Jun 27, 2011 | AT&T E5630 Cordless Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
About a week ago we purchased a new cordless phone with a second handset for upstairs. It is a Uniden Dect 6.0. Without warning the 2nd handset's buttons ceased to function. It still receives signal but...
Try putting the 2nd handset in the base station for a few minutes. Sometimes this helps it reset.
Alternatively, just switch the handsets and see if that works.
Sep 06, 2017 | Uniden DECT2080-2 Twin Cordless Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
Caller id not working, called tele ph comp they said to change batt, have base unit with one in other room, base one and two not showing caller id, the batt are showing full.
Caller ID information is passed between the first and second rings.
Try connecting a regular corded telephone or a standalone Caller ID box. Does Caller ID information show up?
If you have multiple telephones (I don't mean a single cordless telephone base with multiple handsets) and none of them are showing Caller ID after 3 rings it would appear that the telephone company does not have Caller ID turned on for your telephone line.
Oct 29, 2008 | Lands Phones
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Uniden TRU 4485-2 Cordless Phone (TRU4485-2) Logo
170 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
