Question about Honeywell HT8002 Table Fan
Wattage for the honeywell ht-800 fan
I have a honeywell ht-800 fan and want to run it on a dc power inverter I just want to know what the wattage rating is i have a 75, 400, & 1100 watt inverter. I don't want to put it on too big of an inverter to help conserve the car battery. thank you
  • 334 Answers
Can you see an amp draw rating on the fan motor itself?
Posted on Jun 20, 2009
Can I replace the blade? Where do I get a replacement blade?
http://yourhome.honeywell.com/home/Applications/ReplacementPartsSearch.aspx
Nov 10, 2014 | Honeywell HT-800 Table Fan
BROKEN BLADE OF TABLE FAN
obtain new blade and replace same.
https://yourhome.honeywell.com/home/.../ContactUs.aspx
Jan 11, 2014 | Honeywell HT-800 Table Fan
How do I get a replacement remote control for an AIRWORKS ceiling fan/light
There are lots of fans with remotes available for under $40.00. I don't think you can find a remote for $40.00
Oct 16, 2013 | Honeywell HT-800 Table Fan
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
The fan at the back of my inverter is running continuously, can you please let me know what might be the problem and how to fix it
If you have it pushed against someting or have too many things around it, it may not be getting enough air to keep cool. That will cause fan to keep running to keep inverter cool.
May 10, 2011 | APC DC to AC power inverter - 150 Watt
How many watt it have?
    Features and Benefits:
  • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
  • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
  • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
  • Versatile design makes this fan great for use on desk and table tops
  • Wall mounts with separate purchase of hardware
  • Equipped with a carrying handle for transport
  • Dimensions and Weight:
  • Size: 6.33" x 11.375" x 11.125"
  • Weight: 3.5 lbs.
    Power 50W @ 110V
    Power 60W @ 220V
Feb 14, 2011 | Honeywell HT-800 Table Fan
Q7 12V socket Inverter Wattage Question
no you need to know the wattage of the item you are trying to power. To find the wattage of the item you are trying to power is simple. Some will say directly others will give you the amps (ie. .5amps, 1.2 amps.) you take the amps and multiply it by the volts that it says. All this info is on the item you are trying to power with the inverter. The answer is what it will take to power that item. example .5amps x 240v = 120 w so in this instance you would need an inverter that would produce at least 120w so in this case the 150w inverter would work. Good Luck, have a grt day
Apr 01, 2010 | 2009 Audi Q7
How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
Cleaning Honeywell table fan
By the way please check my video on YouTube for your answer. Watch, Subcribe, Share, and Comment!
Thank you
" How to Open a Honeywell Fan to Clean" on YouTube
Jun 14, 2009 | Honeywell HT-800 Table Fan
Honeywell HT8002 Table Fan Logo
363 people viewed this question
Top Honeywell Dryers Experts
Rob Sinbad
Rob Sinbad
Jay Finke
Jay Finke
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
