Can't find furnace filter on my furnace..need to change it
I have a carrier furance, model # 349FAD048100, serial # 4487V01020.  It is located in the crawl space under my home.  I bought the house 6 months ago and want to change the filter, but I can't even see where the filter is.  Can you email a diagram, instructions on where it is located...or a way that I can get a manual for this furnace from carrier?  Thank you!!!
Bill Edwards bassbill2@yahoo.com
koolbreezes
  • 540 Answers
SOURCE: AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
  • 108 Answers
SOURCE: can't find FURNACE filter
First you have to get the old filter/s out. If not it will cause big problems in a short time. Use a coat hanger to grab the filter if you cant reach it. When you remove the old filter you will probably see how to install new ones. I think more than one filter is required for this furnace. Note the sizes of the old filters and buy the same replacements.
Don't worry about cutting some tape if needed. You can get another roll at any hardware supply. If all else fails, measure the interior of the return box and buy the right size filters. Remember, you must remove the existing filters!
Ray
Posted on Nov 16, 2008
tborn6
  • 700 Answers
SOURCE: Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Posted on Jan 21, 2009
pierre1811
  • 144 Answers
SOURCE: diagram for 10kw heat pack for carrier furnace
I hope this helps
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/wd-fa4c-01.pdf
Posted on Jan 23, 2009
SOURCE: Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Posted on Jan 14, 2010
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
I recently came to home to find my furance (natural gas) running but it was blowing cold air. I pulled the filter, it was dirty, cleaned it and replaced it. I turned the furance back on and it worked...
You are resetting it every time you take the panel off the front of the unit. It is locking out the circuit board. No. 1 reason for this is a dirty sensor. The flame sensor is the small rod-like part that senses the flame of the burner. It is usually pretty close to the hot surface ignitor (the part that glows bright when the furnace is igniting) Watch your furnace burner light. You will see the ignitor come on. The sensor is a little bigger than a pencil lead and it will be just a couple inches away from the ignitor.
Take the sensor loose and clean it only with fine sand paper or emery cloth. Chances are this will solve your problem. Hope this helps
Apr 21, 2011 | Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
Lenox Gas Furance Summer Fan Not Working
Just curious, there sometimes is a safety switch on the door to the fan unit so no one gets hurt opening it to change filters ...etc... make sure all the doors are on tightly
Jul 30, 2009 | Dryers
Goodman CACF048B2A Air. need to know the location of the replacement filter
The disposable filter is always in the return air of an a/c unit. If your unit has a furnace attached in an upright position then the filter is under the furance blower wheel. You will have to remove the bottom access panel to see and replace it. If your unit is horizontally installed in an attic then the filter will most likely be up in that return air duct or possibly in the return air grille possibly mounted in a hallway or someplace like that.
May 30, 2009 | Goodman CACF048B2A Air Conditioner
Filter location
is this a split system or package unit. if u don't have a filtered return inside the house where the return air is and just grilles( return is the air being sucked back to furnace). look inside the furnace where the blower motor is the filters can be in the plenum above the blower if its a counter flow or if its upflow they might be below the the blower or on the side of the blower. wherever the return air comes back to the furnace look there. also if there is 2 panels behind the flue pipe that may go up remove the right side panel and there may be 2 filters in a v pattern above the blower.
May 27, 2009 | Carrier Heating & Cooling
Knock Noise When Carrier Furance Starts Up
have the ac company check the actual blower wheel itself it may be slowly coming apart
Apr 20, 2009 | Carrier Heating & Cooling
Cleaning electronic air filter
What brand and model is the air cleaner?
Often you can find the mfg. website and download the .pdf file of the manuals.
The air cleaner will be located on the return air duct of the furnace and should have a nameplate and a model# somewhere.
Some use disposable filters and some need to be cleaned with dish detergent and can be very fragile. Hope this helps.
Matt
Jan 04, 2009 | Carrier 38CKC036 Air Conditioner
Filters
you should be able to. you will not hurt the furnace if you put filter in and watch the operation of heater. If the heater gets to hot it will trip out on high limit, then cool down and start again if air flow is restricted to much. The filter will need changed more often than the normal one
Apr 13, 2008 | Goodman GMS90703BXA Heater
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Dec 31, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
