Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Loose blades how do i tighten up the blades
    Problem Solver:
  • 18 Answers
They should be loose swing around if thats not the please clarify
Posted on Jun 27, 2009
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
Why can't I tighten replacement blade sufficiently?
Check the diameter of the replacement blade hole against the removed blade. Similar blades can have different size mounting holes.
Sep 17, 2015 | Saws
Blade spinning loose. Won,t cut grass. Won,t tighten
Most have lugs the blade fit in and washer on bolt.
Feb 09, 2015 | Garden
Why won't my saw blade go on tight. the mechanism that secures the blade won't tighten down good enough.
You need to make sure the blade is centered properly on the washer on the spindle as you tighten the nut. It can slip off while you tighten the nut. Tighten the nut a little at a time while you wiggle the blade to make sure it's seated properly in the washer.
Sep 14, 2014 | Dewalt Heavy-Duty 36V Cordless 7-1/4"...
Changing blade scroll saw
Loosen the knob at the rear of the top arm - turn it counterclockwise several turns. The blade should now be loose. Push the "blade end" of the top arm down slightly with one hand while you unhook the top of the blade. Lower the blade a little to unhook it from the bottom arm.
Replace the blade. Hook it onto the lower arm first - you can look underneath to see what you're doing. The blade's teeth should point DOWNWARD - it's easy to accidentally install it the wrong way, so check that now. Again push down slightly on the end of the upper arm, then hook the top of the blade into the upper arm's blade holder. It should how stay in place, but loosely.
Now return to that tensioning knob at the top rear. Tighten it slowly until the blade is BARELY tight, not loose. Tighten the knob 1/2-turn to one full turn tighter to tension the blade.
Jul 24, 2014 | Craftsman 16" Variable Speed Scroll Saw
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
Can you tighten the belt that engages the blade?
check for a spring loaded idler pulley that keeps tension on the belt out of place.
May 17, 2013 | Toro Garden
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
How to tighten blade
if the blade is unbalanced it will not stay tight and should be replaced then with a block of wood to hold the blade from turning tighten the replacement blade
Jun 10, 2012 | Black & Decker 19" Electric Lawnhog...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,558 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
