Question about Novell Advanced Network Management Self-Study Kit (00662644447537) for PC
Novell dsrepair Hi, I have problems with DS. dsrepair reports error 602 and 625. when i run dsrepair with option -rn, it solves the roblem, but after few days the problem repeats again, also some servers report error11001, can not find net id. Can you please help to solve this error? thanks
Re: Novell dsrepair
625 errors ALWAYS mean that there is a break in communication, which can also mean they just can't resolve or find the address to the server they are trying to connect to, even if its on the same subnet. You need to ensure that all systems can communicate via simple pings, then configure SLP for even better results.
Posted on Aug 27, 2009
0 characters
3 Points
Does anyone know about RN to MSN programs?
I think if you contact the school you're interested in directly, they will be able to tell you about financial aid and tuition costs.
Do you have a BSN or a 2 year degree? If you have a BSN you don't need to limit yourself to RN to MSN programs. These programs are for nurses who did the two-year school and sat for the NCLEX and have experience in the clinical setting as an RN, but want to go on with their eductaion.
I went to an Ivy League out of state for my BSN/MSN (I was coming from another career and already had a professional degree) and I can tell you the costs were ridiculous. By the time I'm done, I will owe well into the six figures.
The great thing about nursing is that regardless of cost, when you come out able to sit for the NCLEX. So the expense is worth it, because as a nurse you will ALWAYS be able to pay the loans back. You will find more information in here about RN to MSN.
Aug 26, 2012 | Educational & Reference Software
I am unable to open the report center in quickbooks 2010
easiest is to check for support and you may have free tech support form intuit. I have found its hard to troubleshoot problems with quickbooks and very little info online unless its on their website
Mar 03, 2011 | Intuit QuickBooks Pro 2010 Full Version...
I've installed the game but when I launch it it gives an error msg: "OT5 has encounter a problem and needs to close...". Dx 9.0c is installed on winxp SP3 on an hp 6400 laptop w/1 gb memory ati Radeon 1300...
The first option would be to uninstall and re-install the game if you have not done so already. This will, more often than not, sort out the problem as this kind of error could be related to corrupt installation files. Also run a full anti virus scan using good software such as Kaspersky internet security 2010, then try reinstalling your game.
Let me know if you still have problems after following the above steps.
Best wishes,
Jul 03, 2010 | The Learning Company Oregon Trail 5th...
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Educational & Reference Software
Hi, Need to create multiple running auto numbers in one table in one field, can anyone help?, am using access2000.
you can add page #'s in reports, insert, page #
you can't add auto #'s in the table without just adding the # in one field for each one
Access is a database program, the report option is where the page or file # is entered
I hope this helps
Apr 08, 2009 | Microsoft Access 2000 Step by Step...
Petz5 installed giving me error report
I had this same problem. So what I did was I went to the Petz 5 folder and clicked on Adopted Petz. I moved all my pets into another folder. Then I uninstalled and reinstalled the game, moved all my pets back into the Adopted Petz folder, started up the game it it was all good! Hope it works for you!
May 27, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
I just bought a copy of Dogz5 with Catz5 attached
Dogz and Catz 5 both seem to have alot of problems! Disk space means you dont have enough room to copy it onto your computer, I would suggest deleting some downloaded things (nothing important though, you dont want to mess up your computer, lol)
Jan 21, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Attempting to install GPS USA
i think the probleme is with ur gps usa package.Either It may be a corrupted one or there is certain installation probleme.
So 1st uninstall it and then reinstall it.
If ur probleme is not solved after reinstalling,then downlod another copy of gps usa from the below link
Oct 16, 2007 | National Geographic GPS USA (PC/MAC) GPS...
Error that wont go away
Please be careful when running any sort of tools on the registry. Since almost everything in windows has a registry entry you MUST be very carefull when doing anything to the registry. IMPORTENT : Back-up the registry BEFORE doing anything to it. The problems you are having right now COULD be because of changes made to the registry. It is hard to know because you didn't post EXACTLY what the error messages were. I can only guess what happened: 1) Possibly references to .net driver paths where re-written or deleted, A re-install of windows .net should fix this problem. 2) The path to your outlook inbox files could have been rewritten and/or possibly deleted. If you cannot find the path to these files (if they are still there) and enter that path in to the registry, then you have probably lost your local copy of your saved email. In that case there is no fix. My recommendations: 1) Always back-up, back-up, and back-up some more (you never know when something will go wrong) 2) Always take note of the exact error messages the computer gives you. It is THE only solution to any problem. Also to save you panicking, most of the registry entries regcure reports on (as with ALL registry repair tools) are NOT a problem. MOST of these entries are MRU entries (recent files applications remember), missing shortcuts, directory's and the like, nothing of which will harm your computer. You really only need to run a registry cleaner once every few months.
Aug 16, 2007 | Microsoft Network Programming for .Net...
Educational & Reference Software Logo
298 people viewed this question
Top Novell Educational & Reference Software Experts
Brian Sullivan
Brian Sullivan
Are you a Novell Educational and Reference Software Expert? Answer questions, earn points and help others
