I partition into xp and i cant browse
Partitioning my vista into xp has cause d my wireless not to connect but i think there still some other which i have not noticed. pls help.
    Sergeant:
    Champion:
  • 253 Answers
Apparently, installing Ubuntu 8.10 via wumi did the trick for some reason and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
How do I setup a dual boot for a PC with Vista and XP? I want XP to start automatically.My laptop is a Toshiba Satellite L355-S7915 that had Vista Home Basic preinstalled.
The first thing you need to do is repartition the hard drive. This will effectively erase the drive because partitions run below the OS level.
You create two partitions and then you can load each OS to its own partition. When the box boots you choose the OS you want to start and thats it...I think if you put the preferred OS in the first partition it will load that one by default.
You need both OS disks to do this so make sure your factory Vista disk works.
Mar 07, 2010 | Computers & Internet
I have partitioned my C drive and now have a 2nd
On the setup you need to select the xp partition if its not visible you will need to load additional SATA drivers when the setup asks you to
Mar 21, 2009 | Computers & Internet
How do i remove windows vista and install windows xp with out losing all my other stuff
If your Vista still work, go to the control panel> administrative tools> computer management > disk management > create an additional partition (larger then my documents folde size)
Move your files to this partition then install xp.
A few tips
  • Make sure there xp drivers for each componenet
  • Use driver magician and find xp drivers (check the pc mfg site and download all xp drivers and put them on this partiton too.
  • Use a partition program (dos) and format the vista partition and the hidden partition that vista creates or xp won't go in properly
Jan 24, 2010 | Microsoft Windows XP Home Edition
Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Sep 26, 2009 | E-Machines eMachines Desktop PC
Problem installing xp
You can install both wista and xp in the same computer, better for this to create new partition (resize ild one and free some space and create partition in its place) then install XP created partition (partition create is possible professional tools paragon partition manager, norton partition magic or other).
afrer restart only XP works, then insert VISTA install cd and "fix boot"
Here is brief discussion about this VISTA>XP or XP>VISTA.
Take care of drivers may some of them dont be created for XP if your pc is super new.
Aug 20, 2009 | Microsoft Windows XP Professional With...
Could not install a new operating system
How you created new partition? You cant see disk partitions in bios! You can see free space or new empty partition when you boot up from xp cd.
Apr 02, 2009 | HP Pavilion dx6667cl 2.2GHz Core 2 DUO...
Delete partition in vista
Volume = Partiton yes
Don't you wish they'ed just keep the same terminology?
Jan 29, 2009 | ASUS F8Sn-A1 PC Notebook
How to install window XP onto Compaq Presario C700
I would suggest first trying to make it a dual boot to make sure you can get all the drivers working. Vista has a resize function for the drive size, and you can install XP in a second partition (probably about half the drive would be nice) There are directions for that elsewhere. You can make a folder on the partition after you install the XP Windows system (Vista should see the XP partition with no problem) and download drivers as you find them in the Vista, which will still have connectivity software running, while XP might not connect until you find the ethernet and wireless drivers. I looked in Google, and found several sites with people looking for and finding the XP drivers that worked. You will need a working copy of the version of XP you want to install, with COA/install numbers for the XP, of course. Good Luck.
Oct 24, 2008 | Compaq Presario 700 470024-192 Notebook
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
