Question about Toshiba 65HX81 65" Rear Projection Television
Toshiba 65HX81 would not show any pictures power light blinking
Yesterday after watching movie i turn off my TV and today when i start nothing comes up on screen RED led which is power light blinks. what could be the problem here an i fix it on my own?
  • 3 more comments
  • Anonymous Nov 24, 2007
    powerlight blinks on and off but doesnt turn the tv on
  • chello32 Jan 07, 2008
    my television will show but is doesn't have color.
  • Normy31 Jan 12, 2008
    Same probem and blinks all the time!
  • brian5331 Jan 26, 2008
    light blinks 2 or 3 times the becomes solid red
  • blazin2 Sep 04, 2008
    power light blinks but tv does not come on.have unplugged tv to reset.Same problem exists.
  • 4,402 Answers
How many times does it blink?
Posted on Dec 25, 2007
Red light blinking and no picture on Toshiba Model 65HX81 how do we fix?
Red power light blinking is shutdown--protective mode.
Before buying a remote I would see what is wrong with set.
The most common reason on this model is a short in the convergence circuit--uses two chips----method to see if they are shorted is to locate (not real easy on this model) and unsolder all 18 pins on each chip--if set turns on then(will look bad) one of the chips is gone and both need replacement.
The other issue this set has is bad Hyper boards that cause noise when cold and operate after warmup---more expensive to fix than a convergence problem.
convergence chips used in this set look like these
Mar 30, 2012 | Toshiba 65HX81 65" Rear Projection...
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Power botton blinks and there is no picture
Unplug the tv for 1 minute plug it back in, turn it on, if the button still blinks and the menu does not come up the tv will need to be serviced. All tv's should see a menu come up when the menu button is pushed.
May 06, 2010 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX81 No Power Issue
ur ignition card/panel is burned change it!!
Aug 16, 2008 | Toshiba 65HX81 65" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Power light blinks and no picture
sounds like loose connections on the convergance amps ic's
Dec 15, 2007 | Toshiba 65HX81 65" Rear Projection...
TV does not turn on
Most likely a bad flyback transformer....circuit board pull +
xformer R & R not for novice.....Part # 1-453-285-21.........T.
Apr 25, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Toshiba 65HX81 65" Rear Projection Television Logo
347 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
