Question about Panasonic PanaFax DF-1100 Laser Printer
Platen Cover is open
DF-1100 Info Code 065 Platen Cover is open, where is this cover?
    Problem Solver:
  • 9 Answers
If you open the platen cover, on the rear middle there is a little opening, that is where a little actuator sensor sit, and it is sticking... take a little flat screw driver and kinda flicker it.... that should take care of your problem
Posted on Jul 10, 2009
Samsung 4623f scanner locked what can i do
dear
pl. knock lightly with your palm of both hands at left and right sidev of. the platen cover while printer in power off. test making power on. else you need to open platen cover for checking free movement of cis.
thanks.
Mar 15, 2015 | Samsung Office Equipment & Supplies
Please i want aa solution to platen cover is open
Try starting by closing the platen cover. If that doesn't do it, then repost your question being sure to specify the make and model of your copier.
Feb 21, 2013 | Office Equipment & Supplies
How to fix platen cover need to closed ir-1210 canon copier
Sep 25, 2012 | Office Equipment & Supplies
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Dell 1600n printer, how can I clean the platen glass?
you will need to take your printer plastics off to clean.4 screws on back panel take out then one screw on left side cover.take out paper tray open toner door 4 screws to remove,turn on side and on bottom there are 3 tabs both sides to remove side panels.one side has a speaker wire to unplug.take off display cover 3 screws to take out.lift off top cover and remove 4 screws 2 each side lift off platen and clean. reverse the order to put back together.take your time and be careful good luck
Mar 11, 2010 | Dell 1600n All-In-One Laser Printer
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
Gestetner DSC530 -- Auto Document Feeder
Normally the cable from the doc feeder has come out. Turn the machine off unplug the cable from the DF to the machine then reinstall it should click turn the machine on then try.
If this doesn't work open the DF cover and check that there are the paper detect fins also when the cover is open then the machine should register a cover open this will tell you if the DF is recognized or not.
Thanks J
Dec 13, 2007 | Gestetner DSC530 All-In-One Laser Printer
Panasonic PanaFax DF-1100 Laser Printer Logo
300 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
