Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Cratfman push lawmover not starting,I put a new spartplug,new gazoline,new air filter still not starting
  • 218 Answers
Hi..my name is Keith..and it could be several things..that your carb needs cleaning..the fuel pick-up tube needs cleaning..if you have no spark..it could be the coil..it could also sheered the key in the flywheel and this will throw off the timing..i hope these suggestions will help
Posted on Jul 01, 2009
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Jun 07, 2014 | Poulan "Poulan" Push Mower
My 91 toyota pickup it's start but suddenly die
hello,
is the gazoline pump flow enough?Is the filter clean?
B.
Jan 31, 2013 | Cars & Trucks
No power less accelater need more gazoline
if you mean you get 100 k/m to 18 liters of gazoline that all about what you will get its working out about 30 mpg which for a 1.8 or 2.0 liter thats all you will get hope this helps ivan
Oct 23, 2012 | Mazda Cars & Trucks
Will not start have new battary, new feul pump, new feul pressure, new plugs and new air filter?
Turn the ignition to on and push on the break peddle and put the car in neutral and it will start
Mar 16, 2010 | 1998 Ford Expedition
I want to change de gazoline filter on my 4 runner 1991 but i dont now where is located the filter can you help me please
on the frame rail next to the transfer case on the left side of the car good luck these lines strip out alot due to rust and the location
Feb 27, 2010 | 1991 Toyota 4Runner
2004 Hyundai Terracan, 2.5 turbo diesel, manual. Will not start cold. Once I get it started, it runs and starts perfectly, with some heat on the engine. Error Code P0110, I replaced the air intake...
right renew the glow plug timer/relay if you put a meter on the glow plugs when cold and turn ign on (with help) it should supply power for a about 20 secs ,time depends on outside air temperature ,if all else fails then do a colin --- use a push button switch,wired to a relay so glow plugs can be operated by pushing the switch which you will mount on the dash ,cant beat a manual overide system
Dec 14, 2009 | 2004 Hyundai XG350
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
