Question about Troy Bilt Tb70ss Gas Trimmer
Trimmer won't start after following instructions
  • runt runt May 11, 2010
    how old is the trimmer,did it run before
  • Jim Parker
    Jim Parker May 11, 2010
    need more information. Did it run properly at any time before and how long ago?
    Jim
    Problem Solver:
  • 7 Answers
Might need a new spark plug if it's more than a year old. I had mine a year and after the winter couldn't get it to start. Replaced the spark plug and it's good as new.
Posted on Jun 26, 2009
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Hs45 backfires spits
Sounds like an over fueling issue, Try resetting the carb to its standard settings, screw both tuning screws right in ant then turn anticlockwise to the following settings H 3/4 of a turn. L 1 full turn. This should set it back to standard. If this doesn't help then it could be a carb diaphram or sticking needle.
Jul 15, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
My echo packpack blower won't start
How long has it been since its been started? If its been a while go to Home Depot and get some fuel stabilizer follow the instructions - if it hasn't been to long go to home depot and get a new spark plug and replace the old one as well as clean the filter -make sure to put fresh oil/gas ratio in the tank - use stabilizer if needed
Oct 25, 2012 | Echo 50.8cc Backpack Blower
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
STIHL BRUSHCUTTER VERY HARD TO STARTAND WON
Could be a fueling issue, check fuel lined and fuel tank vent. Vents can become damaged and create a vaccum in the fuel tank, stopping the carb from drawing up fuel from the tank.
Jun 07, 2012 | Stihl String Trimmer Brushcutter Service...
My 122c trimmer will not start
Does it have a good strong spark, good compression and is fuel getting into the cylinder.? More information is required.
Nov 20, 2011 | Husqvarna Garden
How do you replace the trimmer head on a john deere t105c 2 cycle trimmer ?
Have a JD T105C trimmer that starting "spitting gas out of it" when i try to start it!! It won't start and when it DID, it stalled right back out! Was used VERY LITTLE before this happened!
Nov 01, 2009 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
180 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
