Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Smells like wet dog
The vacuum is made for pet hair so I'm guessing this is an issue with it clogging up somewhere along the way. I clean my pre-filter (blue spongy thing) every other week!
  • 25 Answers
I would do the following: Wash the HEPA filter (the circle shaped spongy one) with a very mild disinfectant mixed with luke warm water. Allow to dry VERY thoroughly before re-fitting.
Replace the filter (they are about $10 australian from the service centre last time I had one replaced)
You may also want to check for moisture in the dust hopper, also in the cyclone bit.
Hope that helps!
Posted on Jun 22, 2009
  • 23 Answers
Try vacuuming up some baking soda or use some carpet deodorizer then vacuum that up.
Posted on Jun 20, 2009
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
What's the best vacuum for pet hair?
Try a bagless vacuum cleaner as hair blocks up bags very quickly. One that is around 2000 watts should have enough power to do the job. As for the price check appliance stores for sales and deals.
May 31, 2013 | Vacuums
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Vacuum blows out dust/pet hair etc. when in use
try replacing the belt if you havent. it almost sounds like your getting weak aggitation. if thats not bad, check for a clog in the brushroll housing nozzle right on the inside by the tube. Replace the inside hepa filter if you havent within the last 3 months.
Jan 04, 2010 | Hoover U5753-900 WindTunnel Bagless...
Wont **** up very much and know my room smells rotten
Even the professionals have problems getting pet stain smells out of carpeting. You need to use a good deodorizer and get the carpet as dry as possible.
Aug 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum doesn't vaccum!
Sounds like there is a clog near where the hose conects to the lower brush part.. Try to look up in there.. Under the brush there should be an opening that goes into the hose.. There might be a clog there..
Jul 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
How to get rid of dog smell
I had this problem along with a clogged filter. I used the solution for clogged filter here on Fixya and the dog smell went away too. It has to do with the flange on the cylinder getting pushed up out of position. Give it a try.
Oct 24, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Jun 14, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
331 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
