Question about Acer Aspire 5000 Notebook
Dvd door will not open
Nothing I have done so far has helped. I think maybe it is a driver screwed up. If so where can I go to get this fixed? Acer Aspire 5000
  • bjrainbow60 Jun 20, 2009
    Thanks so much Bob!! The door opens with the help of a pin but will not load the disk. It does spin but I opened it back with the pin. I cannot seem to get past the other sights and hook up with the real Acer site. Any ideas? Thanks again BJ
    Problem Solver:
  • 13 Answers
There should be a small hole on the face of the drive that will allow you to use a straitened paper clip or a pin to open the drive manually. If there is a disk in the drive it may have come off the spindle jamming the tray. After you get the tray open see if the drive will read a disk and operate properly with the button or software command to open. If nether will open the drive the problem is most likely hardware if the button will open the drive but you cannot open it with a command then the driver is most likely the cause and should be available from Acer.
Posted on Jun 20, 2009
DVD door will not open to eject DVD
There could be 2 reasons, 1. Hardware issue 2. Software drivers:
Fixing 1: Hardware
Make sure the DVD is fixed properly in your tower ( I am not sure whether you are using a tower or lappi)
The direct solution is to put a pin i the small hole present on your DVD player. That should open the DVD door.
To fix the software part.
>> Try to update the drivers depending on the operating system you are using.
>> Download the latest drivers to check if it fix the issue.
>> Open the My computer >> Right click on the CD/DVD drive and select Eject, this will normally open the door.
Else, try to uninstall the drivers from Device Manager and then restart the PC once, this will reinstall the drivers once again by its own if your Windows is up to date.
Please do get back to us, if that does'nt fix.
Jan 18, 2014 | Zenith XBV243 DVD Player/VCR
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
My dvd cd-rom,everytime i turn around i keep having to reinstall
I think you mean it comes out? If so there should be a screw hold under 1 of the covers underneath your laptop where a screw can be placed.
May 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
The DVD/+ of My Acer just stopped working
Sounds like the data connection to the drive has been lost. The power connection is still present, though. i would try to remove the drive, and with a light try to look at the connectors on the inside of the computer and also at the back of the drive. If nothing is obviously wrong, blow the area out with air and plug it back in. If this doesn't fix it, start looking for a new DVD drive for the computer. Good luck!
Nov 07, 2009 | Acer Aspire 7520-5185 Laptop
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Laptop trouble
There is a problem with your DVD drive, then. I think it is unable to detect because there is dirt on the delicate little lens or some other problem.
Clean the lens with a cheaply available lens cleaning disc a special anti-static cloth made for these purposes.
Or see if the PC itself detects the drive. If it doesn't, restore the system to the time when it was all okay. Use System Restore.
If nothing works, show it to a doctor, and maybe you have to change it.
Nov 27, 2008 | Acer Aspire 4720 Notebook
How do I take out the dvd/cd rom drive from a Acer aspire 360 pc
Open the c.p.u ,unplug both the cables with the cd/dvd rom ,Now you will find some screw on the cd /dvd rom .use the screw driver to open screw from left side as well as from right side...now push the cd /dvd rom outside ..............that's it
________________________________________________________
If this answers your question please rate this as fixed.
Jun 01, 2008 | Acer Computers & Internet
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Hitachi dz-mv550a dvd door jammed
when you get to the small rectangle hole use a small flat screw driver. you'll see the lever on the door side. put you're screw driver to the front and pry it backwards and it will unlatch.just pressing on it won't do anything.
Aug 27, 2006 | Hitachi DZ-MV550 DVD Camcorder
Acer Aspire 5000 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
