Question about Bestec (ATX100-5) (ATX1005B) Power Supply
I have a HP M 7160 that will not turn on. There
I have a HP M 7160 that will not turn on. There is a green light on the back of the power supply that is flashing. Any ideas ?
    Novelist:
  • 79 Answers
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Posted on Jul 06, 2009
HP PAVILION A 1520N pc DESK TOP does not turn on when power button pressed. has power to end of cord. Power button does not light up. little green light on back by power source blinking green
Bad Power supply. Look on the side of your current power supply and find the wattage rating, and buy one of the same rating or higher. Some place like newegg.
Feb 24, 2011 | HP Pavilion a1520n PC Desktop
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Hp pavilion 513n tries to start up then turns off
This is a case where something that is getting switched on during start-up is causing the power supply to fail... probably due to a short. How ever I believe the short is in the power supply
This is an older HP model ( I have a 530N) with teh same problem. I bought a new power supply and installed it.
Aug 14, 2009 | Computers & Internet
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
My hp a6130n desktop computer won't turn on after a lightning storm. The power supply is good (the little green light in the back comes on) the switch is good - tested it, so I wonder what is wrong - is it...
i got the same problem accept it didnt involve lighting storm thunder when i turned it off then i try turning back on it would start any help seems like the motherboard is fine the lil green light on back is on also can figure the problem help plz?
Jul 06, 2009 | HP (D7580-60003) Motherboard
Our HP Media center pc will not power on. I push the button and the button does not turn green or power on. A green light on the back flickers, but that is all. I forgot to ask if it could just be the...
Make sure the switch on the back of the power supply is set to the position that has the line on it. If you still can't get any power, then try another known good power supply, if you still don't get any power then you know the motheroard is bad.
Jun 12, 2009 | HP Pavilion Replacement 200w Micro ATX PS3...
Bestec (ATX100-5) (ATX1005B) Power Supply Logo
286 people viewed this question
Top Bestec Computers & Internet Experts
Lawrence Oravetz
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
