Question about Apple iPod touch
Umm my ipod touch froze at the turn off screen ;it just stayed like that and i cant press anything. When I tried to restore it iTunes said that it cannot contact the iPod server or sth....plz help ASAP
    Problem Solver:
  • 12 Answers
1- you need to be conected to the internet!!!
2- go on yo tube and type in how to put an ipod toutch in to drm mode
3-once yove done that plug in to iTunes and click restore
hope this helps
dale gough
Posted on Aug 11, 2009
After i tun my ipod touch on is stays on a black screen
Tweaking the brightness settings on your iPod touch saves your eyes from unnecessary strain.
Changing the brightness settings can be done quickly if you're on the go.
Adjusting the brightness of the screen can make the device brighter if you're in a dark environment or darker if you're in a bright environment.
Alternatively, you can set the device to automatically adjust to the level of brightness it's exposed to.
Press the "Home" button to return to your iPod touch's home screen.
Tap the "Settings" app.
Tap "Brightness." A scroll bar appears at the top of the screen.
Press and hold your finger against the circle on the scroll bar.
Drag your finger to the right to brighten the screen and to the left to darken the screen.
The screen's brightness will change as you move the circle.
Alternatively, tap the ON/OFF toggle to the right of Auto-Brightness to have the device automatically adjust itself based on the detected brightness level.
Tap the "Home" button just beneath the iPod touch home screen to save your changes and return to the device's home screen.
if this is not or cant fix the problem you might have restore it to factory settings
You can use iTunes to restore iPod Touch software.
Apple recommends using the latest version of iTunes to complete this process.
Follow these steps to get the latest version of iTunes and restore your iPod Touch software.
Back up your iPod Touch's data to your computer before the restore to prevent losing data.
You'll need to reinstall it after the restore process.
Connect to the Internet and install the latest version of iTunes from the Apple website.
Make sure your iPod Touch is connected to your computer.
Pick "iPod Touch" in the Source pane of the iTunes program.
Click on the Summary tab.
Choose "Check for Update."
Select "Restore" and follow the instructions to finish restoring your iPod Touch.
although it does sound like a hardware problem with the ribbon cable leads so if this fails and you are tech savy you could try to open it up and to have a look
hope this helps
Oct 17, 2012 | Audio Players & Recorders
I can only hear the music on my ipod when my earplugs are are plugged into it or when it is plugged into my ihome. Cant hear anything when its just by itself.
Turn off your iPod by pressing and holding the sleep/wake button on top (power button) until the red slider appears, then slide to power off, bring it up again by pressing and holding the power and home button together, let go of the buttons if the apple appears on the screen, this is a soft reset, turn off bluetooth if it's activated. Restoring your ipod with itunes will refresh and keeps your software updated and will isolate if it's a software or a hardware issue. Make sure to transfer purchases to your itunes library and back up your ipod touch data before restoring, if issue persist after restoring, consider a hardware repair. Hope this helps!
May 21, 2011 | Apple iPod touch
My apple Ipod Touch is fully charged but will not display any of my music I downloded Screen stays blank, shows no data or anything cnnot get it to sync either
    Complete a Regular Restore
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch. Complete an Advanced Restore
  8. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  9. Plug the iPod Touch into your computer.
  10. Power on the iPod Touch.
  11. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  12. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  13. Return to the above section and follow those steps to restore your iPod Touch.
Sep 24, 2009 | Apple iPod touch
I have a disabled ipod touch 8gb,i cant connect it to itunes
You may need to restore it...
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
But you will lose all your data
Sep 19, 2009 | Apple iPod touch
When i turn on my ipod touch it just says connect to itunes when i do nothing happens cant access anything.
you have a software cooruption. the only way to fix this is to do a restore. try plugging it into itunes and see what happens. if itunes recognizes the ipod it will tell you to restore it. if itunes does not recognize the ipod you need to unplug the ipod and turn it completely off. then you need to plug the ipod while holding the home button down until itunes recognizes the ipod and then it will tell you to restore it.
Aug 23, 2009 | Apple iPod touch Second Gen (8 GB,...
Cant slide to Unlock
try holding down the "power" and "home"buton untill you i pod shows the apple logo then try again it will take about 1 too 3 mins to restart
hope this helps
dale gough
Apr 14, 2009 | Apple iPod touch
Shows to connect to itunes on the screen
The ipod should let you do a restore in itunes with the computer that last synced the ipod. This is the only way to remove the passcode.
If it wont simply show up on the computer, plug the ipod in, hold the power button and then slide to power off. Press the power button, as soon as the apple logo appears press and hold both the top power button and the home button together until the orange triangle appears. This should put the iPhone into restore mode, open itunes and restore.
Nathan.
Apr 09, 2009 | Apple iPod touch
Ipod nano 8GB 3rd generation FROZEN!
Try this: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
Dec 06, 2008 | Apple iPod touch
My ipod touch froze
im having the same god dam problems! this is really stressing me out!! im soo god dam **** at apple for selling a piece **** like this for a high *** price then sell a ipod touch 3g for a cheaper price!!
Sep 01, 2008 | Apple iPod touch
Apple iPod touch Logo
108 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
