Question about Electronics - Others
I have a Lexmark x3350, just installed new ink and when printing I get black ink smudges on the the right side of my papers. How can I clear this problem.
    Scholar:
  • 169 Answers
Well its just an issue with the printer drivers on the computer.What u need to do is unistall the printer drivers from the computer ,by going to control panel>printers and then plug off the printer,restart the comuter and try a plug and play.try this this should work.
if you want a technician to do the entire troubleshooting for you.You may get in touch with
one of the techbuddies,they offer free technical support for such issues.
you may get them at http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Jul 21, 2013 | Epson Office Equipment & Supplies
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
1. Turn the power to the printer "off."
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
May 05, 2009 | Lexmark Z715 InkJet Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Lexmark X3350 - Will not print
If this is a brand new cartridge right out of the box and it doesn't work, check for any residue from the blue tape you removed before installing it. If it still fails, I would assume it is defective and return it for a replacement.
Mar 02, 2009 | Lexmark X3350 All-In-One InkJet Printer
Printer not printing
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now try to Print i am sure it should work.......... Good Luck............
Jan 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
QUESTION
Facing the X3350, the black ink cartridge goes on the left, the color on the right
Dec 22, 2008 | Lexmark X3350 All-In-One InkJet Printer
Electronics - Others Logo
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
