Bsidebob@hotmail.com Sharp AR-287 / L6-10 code Please provide pricing for the laser unit if this is the indication?
  • bsidebob Jun 22, 2009
    In reply to the 'email' regarding a solution to my problem?
    I'm still awating a reply, any takers?
  • bsidebob Jun 26, 2009
    Is there a way to verify that this laser did fail, or that something else could possibly be the cause of such failure?
    I've seen laser unit failure before on the infamous HP laserjet 2P, and the ancient HP3 models (not a pretty picture). I've also seen Sharp laser units not be the cause of the error code.
    Is the dependability of this machine worth the repair cost?
  • 143 Answers
L6-10 is a laser failure code.
Part number: DUNT-6984DS53
List price is$539.03
Posted on Jun 26, 2009
  • wallan Jun 26, 2009
    This is a pretty old unit and has VARIOUS other potientially serious issues. If it were me, I'd not spend any more money on this machine.
Windows 7 unable to detect Sharp Ar-287
Hi
Verify if your Windows 7 is 32 bit or 64 bit, than download the driver accordingly from the Sharp website. Also try upgrading the driver ,it helps.
Please check this link:-
http://xpdrivers.com/printer/sharp/ar/ar-287/_5_6753.cfm
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 06, 2011 | HP Computers & Internet
Error Code E7-11 on a Sharp AR-287 photocopier
This code is related to laser unit functioning problem. Power the machine off and on and if it appears again, do the following;
  1. Open document glass and clean inside mirrors and document glass with a clean dry soft cloth and test.
  2. Check flat cable that connects copy lamp and attach firmly from the main board.
  3. Replace the laser unit if the above fails.
Ask for assistance if you doubt from a qualified technician and you will succeed.
Dec 20, 2010 | Sharp AR-M205 Copier
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
181 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
