Question about Garden
Need to sharpen my blades.not sure exactly how to
Need to sharpen blades on a 50 inch Swisher w/3 blades. Don't have a manual for it. Would like steps to do it right if possible
  • 61 Answers
There should be a bolt in the meddle of each
blade 9/16 or 5/8 headed bolt remove the bolt sharpen
blade w/grinder and replace same as removal
Posted on Sep 06, 2009
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
Jul 29, 2014 | Swisher 60" 13 Hp Trailmower #T1360h
44 swisher
THAY SHOULD MOOVE THE ONE THAT WONT MOVE NEEDS BEARINGS
Apr 27, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
I got alot of vibration when i engage the blades on my 44 inc swisher rough cutter
I had the same problem twice. The first time happened when the blades were not swinging freely because they got gummed up with grass. So make sure your blades pivot easily.
The second time happened when the nuts came loose from the blade driver (the part underneath the deck that the large bolt goes through to hold on the blade assembly). I had taken the Swisher to a small engine repair place for servicing. They removed the blade assembly to sharpen the blades while it was there but put the old lock nuts back on without using any Locktight, so the nuts started to come off while I was cutting. Unfortunately, I did not notice this until after the blade driver got very loose and then got reamed out by the wobbling of the large blade assembly bolt. I had to replace the blade driver and its bolts and nuts.
May 09, 2012 | Swisher 44-Inch 12.5 HP Trailcutter...
Have troybilt 50 inch dwell things {no sterring wheel} o turn. How do you change the blades? Blades very dull.
Jack your unit up and unbolt the blades from the shaft(s). Sharpen and balance or replace. Good luck...
Apr 20, 2011 | Garden
I HAVE SHARPENED THE KNIFE BLADES HOW DO I SET THEM IN THE PLANNER
Planer blades can only go in one way, the set plate must go into the groove on the blade. If you sharpened them by hand, or even with a machine, you have to be absolutely sure both blades are EXACTLY identical and that the edges are true and straight. If not you are going to get some real interesting patterns on your wood. It's rarely advisable to sharpen planner blades and they are cheap enough to make it unnecessary.
Dec 23, 2010 | Makita 3-1/4" Planer Kit N1900B
What causes the grass to row up?. We've had a rainy summer and sometimes the grass gets a little taller than normal.When it rows up and turns brown the yard is very unsightly. It seems to be coming out...
You may have worn blades that dont overlap anymore.
You should take your blades off and have them compared to new blades and see if they are a little shorter than they used to be.
If not....have them sharpened and put them back on. Check your Swishers belt tensioner to make sure the blades are all turning freely.
Aug 23, 2010 | Swisher 44 Iinch 11.5 Hp Trailmower...
Smaller belt on my swisher pull behind mower keeps breaking
make sure it's not coming into contact with any sharp surfaces
Jun 26, 2010 | Swisher T14560 T - 60" Trailmower with 14...
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
I need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
