Question about Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum
Coils in hose attachment collapsed at top causing hose to collapse and not suction, how do I fix this?
  • kccat5 Jun 20, 2009
    TY I called Bissell. They are sending a replacement free of charge.
  • 23 Answers
To fix it properly you need to replace the hose. If you are low on cash try going to a thrift store and get a used one. If you put something in the hose to prevent the collapsing it will quickly clog the hose.
Posted on Jun 20, 2009
Hose collapses
If you're sure the hose and any attachments is clear of debris, you should contact the manufacturer.
Jul 28, 2015 | Vacuums
We have a30yr old electroux that has been loosing vaccum. i took it apart and found a black foam rubber althrough the cannister and on top. i guessu i8ng that foam has something to do with the vaccum.
The foam may be a sound suppressor. Your vacuum may need a new hose. Old hoses have a liner on the inside that can collapse. Try removing the hose and see if you have good suction on the vacuum without the hose on. If you do it. Means the hose is bad or clogged
Mar 27, 2014 | Electrolux Vacuums
I put a new bag in my electrolux 2100 and it seems like it has half of the suction. What seems to be the problem. Does it need a new upper motor gasket?
Take the hose off, turn the vacuum on and see if there is good suction at the vacuum where you attach the hose. If there is good suction at the vacuum there is either a clog in the hose or if it is an old hose the liner inside the hose may be collapsing when you turn the vacuum on. If that is the case you will need to purchase a new hose. I have hoses for sale on my website and on ebay.
Mar 06, 2014 | Vacuums
My Dyson DC07 vacuum works on the floors, but when I pull out the extension wand the coiled hose attached to the wand collapses and no suction goes through the hose?
Hi there, it sounds like you have a blockage in the hose. I have made a video to show you how to get the hose off and linked it to this answer. It is possible to split the hose in places trying to get the blockage out so try not to be rough. If you do damage the hose you will need to buy a new DC07 hose it is a waste of time trying to repair. If this was a helpful answer please take a moment to rate it or leave a testimonial.
Feb 20, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
How do you remove the hose to ck for blockage?
If the hose collapses and there is no suction, that is a sure sign of a clog. The clog will be on the opposite side of the collapsing hose from the motor. Good luck.
Mar 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I took the trap(or whatever it's called)off the bottom right corner to check for an obstruction as my hose was collapsing when using the attachments. Put it back on(perhaps wrong)and now when the vacuum is...
now you have a dyson leaf blower! not funny huh? Ok, just slow down and recheck your connections. Sounds like the motor is running backwards or you are hook up to the discharge. ck for baffles that block off the vacuum to the roller part when attachment is installed. If hose was collapsing then the restriction was or is in the hose. Don't poke through hose with anyrhing but a rounded end broom stick or you chance tearing the hose. Take machine outside to test run, but I think you already thought of that .:) Good luck. Will get back to you in a bit.
May 04, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dysom animal long hose collapses
check the hose and be sure it isn't cloged this is what causes a hose to collapses
Jan 24, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
http://dysonmanuals.llc.nu/
Aug 03, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum Logo
142 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
