Question about Electrical Supplies
My Troy-bilt generator will not generate watts
My Troy-bilt generator starts on first pull. the problem is it will not generate watts.
  • Anonymous Mar 27, 2014
    frequency is 62hz
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
  • 154 Answers
Nedds to be regenerated by the use of a drill. intructions on the net
Posted on Jun 21, 2009
I have a similar problem, however the root cause was user error. I had an 8000/13500 generator. I hooked it to an electric furnace and smartly disabled one of the two 6KW heating elements to keep the load under 8KW. It stopped producing electricity a few hours later. So what't the problem? It was dawing 6KW on one phase. The generator produces 8KW on 2phase 220V. The max load on each phase is 4KW. Oops. The load should also be balanced between both phases if possible. I hope this helps prevent others from burning out their generator.
Posted on Jan 10, 2010
What size engine does a troy bilt model 01925 generator have
need to know the KVA or KW rating of the set
Jul 08, 2018 | Troy Garden
I am in need of an owners manual .pdf for a troybilt 6000W generator model 030475A
Wiring diagram (link below) and a link to Troy Manuals PDF Manual Web Archive - requires serial number to access
A good site for manuals or seeking of Free User Manuals and Owners Guides ManualsOnline com
Dec 11, 2014 | Garden
Troubleshoot troy bilt generator
Check that the GFI receptical is not tripped Check that there are no blown fuses or tripped breakers Verify that the engine is running at full RPM If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Aug 30, 2014 | Briggs Stratton Portable Generator 305cc...
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
I need a manuel or starting instructions for a 8000 Watt Troy Bilt generator.( Model number 65157/30247. This is an electirc or manuel start.
See this webpage for manual:
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/030247-0/Troy-Bilt%20Portable%20Generator%20Operators%20Manual/030247_0esCw/
Feb 19, 2011 | Garden
How do we get a troy-bilt operators manual for a snowthrower model #31AH63N2711
need a replacement manual for a troy bilt generator 5500 watts
Dec 26, 2009 | Garden
I have a Troy Bilt 7800 portable generator. It produces no power.
Make sure the generator/alternator is being driven by the engine. Couplers fail often enough to consider the possibility.
Sep 14, 2009 | Electrical Supplies
Electrical Supplies Logo
2,983 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
