Question about HP Pavilion dv5000t Notebook
Display settings were incorrectly set on the hp pavilion dv 5000, when computer is turned on the system boots in to windows (xp home editin), but monitor is blank, how can i reset the display settings, have no discs for hp system or xp home edition
  • watkins_fred Jun 20, 2009
    booting into safe mode was the 1st thing i tried, screen still comes up blank
  • watkins_fred Jun 22, 2009
    • did not think too look for bios, but it did not show up, windows logo did , but screen goes blank after that, managed to get screen restored by using Spotmau disk, repair xp, inital responce asked me too change screen resolution, which i did and now is working ok, thank you for your responce, it did make me think to try other avenues
Boot into safe mode to reset the display settings.
http://kb.iu.edu/data/agjg.html
HTH
Posted on Jun 20, 2009
  • zcx2009 Jun 21, 2009
    When you turn on the machine
    - do you see the POST messages from the motherboard BIOS?
    - do you see the Windows XP logo?
    At what point does the screen go blank?
Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
Apr 05, 2010 | HP Pavilion dv8000 Notebook
Hello, I have a problem with hp pavilion dv
Try lowering your display settings when it is hooked up to the external monitor. Then try the laptop screen again.
Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 13, 2009 | HP Pavilion dv6000z Notebook
Need a recovery disc for Pavilion dv-5 notebook
Hi:
You most likely have a bad hard drive, and a disk set is not going to help you, though you will need it too.
What you need is a new hard drive, a copy of all the drivers for your laptop, which you can download for free from HP. If HP won't send you a copy of the recovery disk, you can use any OEM copy of the same operating system that your laptop has a sticker for, but you won't have all of your programs.
Nov 23, 2009 | HP Pavilion dv5-1140us Notebook PC
Can't get drivers for windows xp operating system
Please try system restore to factory settings and remember to backup your documents.
Good luck.
Apr 14, 2009 | HP Pavilion DV2910US Laptop
IE 7
Yes you can upgrade your Internet Explorer to IE7 (assuming you have IE6 right now)
You can download and install IE7 from Windows updates or go to the Windows Support Site to download it at http://support.microsoft.com
Only upgrade to IE7. Do not download and install IE8 Beta. It is still in testing. IE7 will not cause any problem with your HP Pavilion.
Jan 31, 2009 | Microsoft Windows XP Media Center Edition...
I recently removed and replaced the same hard drive in my laptop which is an HP Pavilion 4400. I booted it up today and I get a message that says there is no operating system detected. The computer will...
Sounds like you bought your new hard drive clean with no . You simply need to put in a boot disc, such as a windows XP installation disc for example, and go through and install the operating system. Look through your CDs you got with your laptop to find a disc with a windows operating system on it, for example Windows XP Home. It may say 'press any key to boot from disc...' along the line so just press any key and you will be on your way to setting up your new system
Hope This Helps
Nov 19, 2008 | HP Computers & Internet
Sleep mode PC continued...
VIA KM400A is the name of the motherboard chipset inside your computer.
I'm fully familure with that board.
1. on boot up hit delete or F2 key to enter the bios setup screen
2. once inside the bios setup screen , look for power management settings.
you'll know what to do at that point
You'll want to
1. turn power nanagement totaly off , which is not a good idea because windows considers
it a device in the system and loads a driver for it , so turning it totaly off MIGHT give windows
a heart attack.
2. set
Display Power Management Controled by Power Management = NA or NO
Turn off display after suspend or hybernate = NO
3. save and reboot
Thank you for choosing FixYa!
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Factory settings
If windows still boots ( and the original hard drive is still in the computer) you can click the start button and find the HP Recovery Manager under the All Programs list. It is probably tucked away under one of the HP tabs.
If windows doesn't boot, and you still have the original hard drive you can press F11 when your first turn it on at the HP logo screen. It should start the recovery program. (The F key can be different on different laptops but most recent HP's are F11)
Be careful, doing a System Restore will erase all your Data, so backup anything important!
Nov 13, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv5000t Notebook Logo
235 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
