Question about RIM BlackBerry 7250
Roller Ball on side of phone will not depress
Is there a document for performing the functionality of the roller by using other keys on the keyboard?
    Problem Solver:
  • 8 Answers
Have you cleaned your roller ball? stick a paper clip point in the top of the metal ring and pop your ball and holder out. you can remove the plastic part from the ring and clean the parts wth compressed air and then a cotton swap dipped in rubbing alcohol.
Posted on Jun 20, 2009
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Cannot change toilte paper
The B-2740 has a concealed locking mechanism to prevent theft. To release there is a small hole at the end of each spindle where you insert a special key to depress and release the locking mechanism. If you do not have the special key you can use a pin or nail that fits through the small hole.
To order the special key it is part number 822-25 Bobkey - Spindle.
Contact your local Bobrick dealer or contact Bobrick via their Customer Service:
http://www.bobrick.com/Bobrick/ContactUS.aspx
Feb 07, 2011 | Bobrick B-2740 Classic Series...
I have a Canon Color Imagerunner C3220 copier. When I try to print 8 1/2 x 11 documents and send to the copier for printing, it keeps jamming. This is on the left side in the fuser area.
the uneven pressure of the fuser rollers cause this problem ,roller ball bearings needs change ,temporary solution try to add a little pressure on the roller by tightening the adjusting screw both rear and front (underneath the yellow cover)
Jul 15, 2009 | Canon Office Equipment & Supplies
My roller ball goes up and down but not side to side please help!
The roller balls on Blackberries are notorious for this. The problem is that they get dirty. It is possible to remove the ball and clean it but that will void your warranty. I suggest calling your service provider and getting it replaced under warranty if the phone is less than a year old. If it is over a year old the warranty is expired already and you might as well take it apart yourself. You can find instructions on how to do this HERE
Apr 22, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
Roller ball
All you have to do is take a sheet of paper with print on it. Take the battery out of you phone. Next do a figure eight motion with the ball side down on the phone about 10 times. There is something on the ink on the paper that will make this work again. good luck
Feb 12, 2009 | Verizon Communications BlackBerry Pearl...
Camera on phone will not zoom
Have you tried to remove and reinstall the picture application using the blackberry desktop software.
Dec 09, 2008 | RIM BlackBerry Pearl 8100
How do I change the SIM card in my BB Pearl 8130
Take SIM card out of old phone and put it into the new phone, however first of all you need to backup your old device.
Download the Desktop Manager and connect via USB cable and backup old handset, insert usb into new phone and restore to new phone thus moving all data from old to new.
Gadget
Dec 03, 2008 | RIM BlackBerry Pearl 8100
I have model pc7530
Are you using an Optical mouse, Wireless Mouse or a Roller Ball mouse? If its a roller ball, turn it over, twist the cover as the arrows show, remove the ball and you will see some rollers around the edges that read the balls movement. Clean the gunk off of them with your fingernail or cotton swab. (NO WATER)
If you are using a wireless mouse, change the batteries and make sure you have a good line of site to the wireless adapter, and RESET the mouse by pushing the button on the wireless adapter. If it is an optical USB mouse please let me know, if any of the above worked. Thanks //D
Apr 25, 2008 | RCA (PC7530) Keyboard
RIM BlackBerry 7250 Logo
98 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
