Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire FRS3R3JB stopped making ice and dispensing water.
I have checked the water line no issues with it. all of a sudden water dispenser and ice maker stopped working.
  • Frigidaire Master
  • 4,655 Answers
I have been studying your model most of the morning. The only thing I could come up with that would cause this is an electronic dispenser control. It may be defective.In the control the power is converted to DC and the water control valve work off of DC voltage. I am putting you with the best his name is Brian. His website and blog are different. Website==> http://www.technicianbrian.com/
And here is where most of his help is directed ===>
LINK TO --> TechnicianBrian
one of my sites===>http://appliancepartsandtechnicalservices.blogspot.com/
If you have any problems let me know, Sea Breeze
Posted on Jun 20, 2009
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
FRS262GEB Side By side Not Making Ice
Typically when this problem occurs there is a clog of some sort between the filter and the ice maker. Disconnect the filter, stop your icemaker and take the fill line off. Blow compressed air from the filter side, until air blows freely. Reconnect all parts and turn unit on.
Aug 22, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Frigidaire frs28zrg with puresource water filter purchased used so probably 3 to 6 yrs old maybe more. The dispenser stopped dispensing water rather suddenly, but it's still making ice. We...
Check the reservoir behind the crispers for frozen lines. If it is froze it will take several days to thaw out with the frig below 40 degF. If it is not frozen you can disconnect the line at the water valve and see if the lever is operating the valve. Switch, water valve and waterlines and filter. process of elimination to find the culprit. Eric
Jul 08, 2009 | Refrigerators
Water to the Ice maker and water dispenser has stopped
check to make sure the valve is not froze if so water cant come thru
Nov 11, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery Series M# GLHS36EESB5 S#LA53808237 The indoor water dispenser stopped. I replaced the filter but nothing changed. The fridge is 18 months old.
check to make sure there is nothing blocking the water lines and no kinks in the water lines, you did not say if it had an ice maker, and if it is affected.
The frigidaires also has a plastic tube coiled under the back to dispense cold water make sure this tube is not kinked.
Hope this helps
Jul 02, 2008 | Frigidaire Refrigerators
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
339 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
