The picture size/aspect is set on small.. i would like to set it at wide 16:9.. my problem is, i do NOT have a remote control... I can only do this manually on the tv...
  • 3,230 Answers
Well, these kinds of functions are works only with remote, so you need a remote to do such settings.
Thanks
Posted on Jun 20, 2009
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
Oct 03, 2014 | Samsung Televison & Video
My philips tv has an expanded picture,meaning the picture is so large does not fit the tvscreen. and my remote control is broken can i buy one?
You can purchase a remote or get yours fixed at www.replacementremotes.com
BUT the picture size is normally adjusted with your cable/satellite remote or from within the cable box's/satellite receiver's menu. On the cable box remote the button is usually #hdzoom and on the satellite receiver it is usually aspect or format. For settings make sure the set top box is set to 16:9 disabling any 4:3 override. Set to 1080i fixed or 720p for the resolution. You may have a choice of 1080i cropped, stretch, wide or etc. and that is where you play around with the settings in order to get the right size picture.
May 11, 2011 | Philips Televison & Video
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
How do I make my tv pic full screen? My tv programs are shrunken to small screen...
GO TO MENU ON UR REMOTE CONTROL AND SELECT PICTURE SETTING .....
THIS OPTION WILL GIVE U THE PICTURE SIZE ON UR SCREEN U LIKE TO SEE....REMEMBER NOT ALL PROGRAMS ON TV ARE IN FULL SCREEN MOODE
Nov 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
42' hd tv has stretched picture makes people look fat
you have a few settings to size the picture as best as it can be sized.
format, aspect and size . try setting the TV (remote) format to full, fill or just.TV size to 16x9.
If also using a cable/satelitte remote set it to 16x9 size, stretch format/aspect and 1080i output. then just press the # key on cable remotes or format key on Sat remotes to size it best on each channel.
with 16 formats available, today's TVs are doing their best to keep up.
hope this helps
Eric
Aug 29, 2009 | HP PL4260N 42 in. Plasma HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Apr 25, 2008 | Hitachi 51F500 51" Rear Projection...
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
