Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi BC30 Weedeater - Cannot Start
My weedeater referenced in the subject line will not start. I have checked the fule lines...clear...muffler is clean and clear. When I first pull the cord, it sounds like it wants to start at the very beginning but it won't keep going.
My uncle suggested adjusting the fuel mixture by turning two screws. I have adjusted those screws every way possible (that;s how I got it to act like it wants to start in the first place) but it will not turn over.
Any suggestions?? How do I adjust those screws correctly?
Any help would be appreciated.
Dan
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Jun 26, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
MY ryobi bc30 expandit starts,but the weedeater head is not rotating
The drive may be broke. It travels from the head to the engine. The drive spindle is attached in a hole at the engine and the engine rotates the spindle to rotate the head. The drive spindle must be broke inside the shaft, the engine or the head. If this is the case, a new weedeater will be a better option.
Jun 04, 2010 | Top Expressions " INDUSTRIAL SPRAY PAINTER...
My ryobi weedeater will start in the choke or low position but will die when you switch it to the middle or high position.
It's the muffler. Everyone thinks fuel, carburetor, mixture. They're wrong. The muffler is clogged and the unit can't be tuned to high throttle until you clean it.
Steps: Remove the back housing to access the muffler. You may want to remove the gas tank to avoid a spill. Remove the muffler (2 large screws). Remove the muffler door (3 small screws). The screen should be cleaned using a pin (poke out any hardened material). Most important: The muffler door is 2 parts. Pry it apart and scrape off the burnt carbon that is clogging the exhaust path. Re-assemble and start.
May 02, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
I have a ryobi weedeater model 764r. how do i reset the mixture screws.it won't start.
I replaced the gas line hose and the spark plug on a 2075r ryobi proffesional weed eater. Now it will not start. Thank you
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weeda eater
i have a ryobi BC30 bought july of 2007, it has always worked well for me ...but not when i start it , it will only run with the choke on ...... once i take off the coke it stops running........... is there some one out there that can help me get this trimmer ideling again.........  thank you
Aug 28, 2007 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,237 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
