Question about Sony Handycam DCR-DVD108 DVD Camcorder
Sony dcr-dvd108 > cannot use this battery on this camcorder
Receiveing the error message "cannot use this battery on this camcorder" , Have got a new battery, but still the same error.
  • who981 Jun 24, 2009
    anybody out there?
SOURCE: error message
hi i have the sony DCR-PC53E camcorder with the error code E:61:10 does anyone have any suggestions on how to fix this problem any help will be more than appreciated
Posted on May 30, 2008
  • 80 Answers
SOURCE: Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Posted on Aug 14, 2009
SOURCE: Sony DCR-DVD108 DVD Handycam Camcorder unable to install software
I didnt know that so many people had this problem, but i can give you a little hint...
I work for Sony support, and i know that sometimes it is not on our hands to solves Sony's problems, so recently i've been on some blogs and reviews about camcorder from Sony trying to help with some issues...
This editting issue it's something common, because the camcorder records on DVDs and the format that it records on is VOB, format specifically made for DVDs, and I mean ALL DVDs, so at the end models like DCRDVD92, DCRDVD7, DCRDVD101, DCRDVD201, models that appeared between 2004-2006 doesnt come with a software that can be downloaded online, this camcorder the DCRDVD108 comes with a sw wich name is PMB wich is AVAILABLE online, (go to esupport.sony.com) , the only thing that matters is that you FINALIZE the disc and then you will be able to import the videos to the computer just plugging the camcorder to the computer and selecting USB CONNECT with a little disk icon on it, software is not compatible with Macintosh OS btw, but you can use iMovie 08 or 09.
Hope that this works for you.
  • 116 Answers
SOURCE: I dropped the Camcorder, SONY DCR DVD108 and now
Error E:61:10 means that some elements of your lens system were misaligned. Now the simplest way to get rid of this problem is to do the very thing that caused it in the first instance. Bang the lens in a controlled manner against a hard surface(wood is preffered) while switching it off and on several times until the fault goes away . dont continue banging it when the fault goes away!
Good luck.
Posted on Sep 28, 2009
arnedevil
  • 48 Answers
SOURCE: Error C:04:00
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Shamelessly copy pasted from another forum.
Posted on Jul 29, 2010
Sony handycam DCR-DVD108 - - error e:61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously(FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Mar 28, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
I dropped the Camcorder, SONY DCR DVD108 and now get an errror message E61:10. Can you help fix it for a reasonable amount or should I just buy a new one?
Good luck.
Sep 27, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I have a sony dcr-dvd108. the battery is fully
it might be battery to used and it's charging quick and loosing power to quick. have tried to change battery for new
Aug 24, 2009 | Sony Handycam DCR-SR300 Camcorder
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
E:61:10
nesesito solucionar el error e:61:10 de mi camara sony dcr dvd 108 si fueran tan amables en eviar un correo ivanted_x@hotmail.com vale chauu cuidense.
Dec 25, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
DVD Error sony handycam DCR-DVD108
Reformat DVD and clean Lens with soft n nice quality cotton swab.
Jul 22, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
435 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
