Question about Freezers
I have a chest freezer called Mondia F 1400. Its not working properly and there is a dial of setting and the red is illuminated? Any ideas?
Its the motor. its packed in and shortening. THE CONTINUITY IS FUSED BECAUSE THE MOTOR IS OLD. HAVE SAME and got same problem. mine is over 20 years old.I am now looking for a motor.
Posted on Feb 03, 2011
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
The light is on but the freezer is not cooling
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Apr 04, 2013 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Hi. I have just aquired an "IGNIS" chest freezer, model AFE 460/IG, class T. On the bottom right hand side of the freezer ther is a dial (from 0 to 3) which can be altered using a screwdriver...
Pretty sure that the slide is for winter and summer operation, you are rite, the 3 position is the cold level and the 3 lights (Yellow, Red, Green). the Yellow indicates a caution,"" not at temp or faulty""the Red indicates the unit is active and the Green indicates at temp and operating correct. This unit is old and not much information is available however I hope from my experience, that will help you, any further problems call Russ on 08 95230552.
DONT FORGET TO VOTE, I SUPPLY MY TIME FOR FREE TO HELP. RUSS
Mar 02, 2011 | Freezers
I have a kenmore freezer model# 253 9185211. I had it in storage and brought it home ,connected it.Red light on top is on. I set the dial on 4. I can hear something turn on,but freezer wont freeze. Lost...
the lock is only to prevent the door from opening, it does not cause the unit not to cool properly. If this is a chest freezer, a not uncommon occurrence can happen in similar situations, used for a while, then not plugged in for a period of time, and when its used again stops cooling. The lack of usage causes the refrigerant lines in the cabinet walls to rust, and therefore the refrigerant leaks.
You might consider a service call just to make sure.
Oct 03, 2010 | Kenmore Freezers
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
Apr 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
We have a 21 cu ft 2009 chest freezer. It is not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 08, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Nov 14, 2009 | Freezers
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
115 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
