Question about Exercise & Fitness
Healthrider s300i Treadmill belt slipping issues
While using my treadmill, every few steps the walking belt seems to slip. I have tried to tighten and loosen the belt but it doesn't help. What can I do to fix this problem? Thank you in advance
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: Treadmill is slipping. Already tried tightening
This sounds like either the drive belt is loose or the walking belt is old. First, check the tension on the drive belt. If the drive belt is not slipping, then walking belt may need to be replaced. I say may because without working on the unit, I cannot say that IS the problem.
Posted on Mar 19, 2010
bwinton
  • 83 Answers
SOURCE: slipping mat
bwinton
  • 83 Answers
SOURCE: belt is slipping on healthrider treadmill
outfield502
  • 79 Answers
SOURCE: Treadmill turns on but none
just change the keypad
Posted on Sep 15, 2010
Walking belt slip, sliding away!
You need to replaced the walking belt and have a professional reset the drive belt to the proper tension.
Aug 01, 2017 | HEALTHRIDER S300i Treadmill Motor Control...
Belt starting slipping, adjusted according to User's manual...belt still slips.
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt.
If then also the belt is slipping then you have to replace the running belt with a new one.
ok
Sep 03, 2011 | Reebok T 1280 Treadmill
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Jun 29, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Motor is struggling to go when weight is applied (when I step on it)
hi it seem like the motor is fine but the belt on the motor either needs to be tightened or replaced. best way to find out is to take off the front cover showing the motor and step on the treadmill. if the belt isnt moving but the motor is spinning then you need to replace the belt on the motor. or you can try to adjust the belt. i had the same problem, i just tightened the belt and everything works fine.
Nov 18, 2010 | HEALTHRIDER S300i Treadmill Motor Control...
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
When I step on the treadmill, the runner stops and
Unplug unit then remove motor shroud the walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting..
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step If your treadmill is equipped with this bolt (very few are) the repair will only require one person.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller.
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Proform 575 Crosstrainer Treadmill
I started up my treadmill after a year sabbatical :) to find that it stops abruptly when I increase the speed above 4 and then when I restarted it as soon as I stood on the belt the motor lagged & then...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 28, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
Exercise & Fitness Logo
811 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
