Question about Garden
Need replacement pump with light
Apr 21, 2009 - light burned out o garden treasures wall hanging fountaing-trying to find replacement - tmerz1
6/20/09 same issue - lighted scroll wall fountain loew's item # 18993 model# FGS-436787 - mkelly
  • Dee Dee Harper Apr 22, 2013
    I do not need the light kit, but the extension that makes the pattern, like a bell shape for my little MD80 container pump. Help!
I have the same fountain and same problem. You need a 10 watt 12v halogen bulb. Just wiggle the tube cover off and pull the bulb out. You can buy replacement bulbs at Lowes or 10 for $7.00 on ebay.
Posted on May 05, 2010
  • amhunter1125 Mar 04, 2011
    Had the same problem and when I tried to pull out the light bulb for replacement the prongs on the light remained in the tube and would not come out... It is impossible to replace the bulb with the prongs still in the tube.
    Alma
How do I remove tank?
Fuel Pump Replacement - Chevy HHR Network
www.chevyhhr.net/forums/how-tutorial.../fuel-pump-replacement-36541...
Jul 13, 2011 - I secured the front tires and started removing the electrical wires, connectors and the main fuel line to the tank. ... As you can see here this where the fuel enters the tank. ... I really didn't want to do this but my mechanic was moving to a new ... LT 1,Tinted windows, Alpine CDA 105, Alpine door speakers, ... I replaced my coolant. Did I make it correctly?
Apr 5, 2012
Check Engine Light for a busted fuel cap? Rip Off?
Apr 29, 2009
Do I need a locking gas cap?
May 5, 2008
why no in-line fuel filter?
Apr 9, 2008
More results from www.chevyhhr.net
AA106 - 2007 Chevrolet HHR 2.4L Auto 77k - YouTube
? 2:18
https://www.youtube.com/watch?v=umTImuWr2k4
Jan 28, 2013 - Uploaded by eallauto
AA106 - 2007 Chevrolet HHR 2.4L Auto 77k .... 2007 ChevyTrailblazer Fuel Pump Gas Tank Remove Replace - Duration: 19:08. by Neatus ...
How to Replace a Fuel Pump : Removing Fuel Tank to ...
? 2:03
https://www.youtube.com/watch?v=FEYYU6lnwWQ
Oct 1, 2008 - Uploaded by expertvillage
Learn about the steps for replacing the fuel pump in the gas tankof your ... He is able to do brake repair and tune-ups, including engine .... Chevy Silverado Fuel Pump Replace In Under 1 Hour - Duration: 22:31. by The Car Doctor 3,216 views ... GMC Jimmy \Chevy Blazer Fuel Tank Removal -Fuel Pump ...
2008 Chevrolet Cobalt - YouTube
Jan 01, 2016 | 2007 Chevrolet Chevrolet HHR LT
Heater pilot light will not stay lit
The thermocouple is either too far from the pilot flame or is bad.
Feb 26, 2014 | Garden Treasures Patio Heaters
Machine not emptying subsequently will not spin what can we do
If you still need to remove the water, setup seperate syphon hose. (Garden hose will do, place the hose in the top of the tub submersed under water, turn garden tap on & when the air is out of the garden hose turn tap off & disconnect the hose, providing tap is lower than the machine the water will drain away through the garden hose.)
Remove the power cord from wall socket, lean machine against the wall at 45Deg angle. If yours is an older machine with the access panel in the front panel access the pump through it...
Disconnect pump.
Put a towel over connectors to stop them getting wet in next step.
The pump is removeable by twisting 1/4 turn anti-clockwise, you need to lightly release the barb clip to allow the pump housing to turn. Hopefully you can now see the debris causing the problem.
Make sure all lugs are engaged when reassembling, if one is not the pump will be hard to turn.
EVEN WITH PRODUCT OFF AT THE DISPLAY PANEL THE DRAIN PUMP IS STILL LIVE, MAKE SURE THE POWER PLUG IS PULLED OUT OF THE WALL SOCKET
Aug 07, 2010 | Fisher and Paykel Washing Machines
The o-ring for my garden treasure pf 1600uv filter needs to be replaced. Do you know where I can purchase one? tfunk@gorockets.org
o-rings come in all sizes usually in milimeters
any hardware store auto parts store stocks them; just bring the old one with you for comparison
Jun 23, 2009 | Garden
Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Apr 12, 2009 | Garden
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Garden Logo
726 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
