Changed ignition cam sensor crank sensor coil still no fire
Hi Wendy, I'm glad to help. If you have the 2.5 liter engine that year has a problem with the Distributor going bad. I'm not sure which engine you have, but if in fact it is the 2.5 liter ave yourself some time and go to the parts store and get a distributor. CAUTION: When installing the distributor on the engine take care not to break the coil tower that sticks up out of the distributor because if you break it the car will not start. Wendy, if you have a different engine disregard this information. Hope this helps and have an awesome day Wendy!
SOURCE: car has no spark or injector pulse(new ecm,crank sensor)
Check the fuse for the injectors, some vehicles have the injectors and coil running on the same circut, at the same time check the fuse for the ignition.
SOURCE: 1997 Dodge Intrepid cranks over won't fire
I have this same NO START problem...
Began with tach giving readings not exceding 1200 rpm with strange 4000 + spikes.. Cruse control would not turn on or off at times and indicator light would only work sometimes..Had several episodes of excessive cranking to get it to start.. Stalling out while driving and even at freeway speeds.. Pulling the negative cable for 10 min. allowed it to start although with lots of cranking and put it in limp mode which required another computer reset to get out of.. Had thrown error codes related to cam and crank sensors which were replaced along with coil and manifold temp sensors.. Had the 9 volt power to sensors when key was on but the check engine light does not stay on with all the other idiot lights..
I wish people who respond would read the post first..
Original post states,
Cranks,No spark,No fuel pump run, changed some sensors ect...
If it cranks it ain't the neutral safety switch, starter or battery!! WAKE UP!!
Seems the computer is not turning on the coil, injectors or fuel pump for a reason.. Find that reason and you will find the solution to the problem.. Seeing as that the computers logic states are a dealer secrete the poster as I have changed many parts in blind hope that it will fix the problem.. Relays, sensors and ecu computer.. Did a visual check of all harness potential wear spots like where it crosses over the power rack..
Could it be in the wiring harness inside the dash??
Could it be a bad ground??
Can an alternator that has failed cause the computer not to start??
Can a bad oil pressure sensor cause the computer not to start??
Can signal loss from the TCU or BCU to the ECU cause this??
Is there an undocumented kill if the ECU thinks it was in an accident??
I can ground the relay line from the ECU and the fuel pump runs and pressures up and the other relays turn on as well..
This crank but no start problem seems to be common with a lot of 1994-2001 Dodge and Chrysler owners.. All these systems have become interlaced with undocumented safety features that baffle the DIYer..If you have seen this and have fixed it PLEASE RESPOND!!!!
SOURCE: 1998 durango 5.2 wont turn over. changed
Crankshaft position sensor? Did you check for a trouble code??? I would have to say at this point there is a code stored in memory.
