Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
Have a troy built pressure washer and the gas is leaking out help
Have a 2 yr old troy built pressure washer 2550 have only used twice...the first two times the hose split right open...just got another new hose and going to use it and the gas is leaking out of it...help
5 Suggested Answers
  • 302 Answers
SOURCE: what grade engine oil is used in the 2550 pressure
mine recommends 30W non-detergent
Posted on Oct 17, 2009
SOURCE: I have a troy-bilt 2550 psi and just use one time
make sure you hold trigger in to relive pressure when trying to start
Posted on Mar 08, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
sinisterfin
  • 16 Answers
SOURCE: I have a 2550 PSI Pressure Washer Troy Built by
Try a lawnmower repair shop or use miliput to cover the welds clean & dry the tank blend it half and half roll it out flat then mould it around the whole of the tank over the join with about ten to fifteen mm spare both sides then mould & smooth it into place, it's fantastic stuff but make sure the tank is clean & dry & give the milliput plenty of time to dry if you do it right it will probably out last the pressure washer.
Posted on Dec 08, 2010
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
Jul 27, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
the float is stuck you can either take it apart and clean it or you might get by by just tapping lightly on the fuel bowl on the bottom of the carburator to unstick the float
Jun 20, 2009 | Garden
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
226 people viewed this question
Top Briggs Garden Experts
Mike
John Trevino
Marvin
Marvin
Are you a Briggs Garden Expert? Answer questions, earn points and help others
