Question about GE Refrigerators
The original and the first replacement water filter lasted approx 6 months. The next two water filter replacements lasted about 2 weeks. The cause and solution of the problem please.
  • douglynette Jun 20, 2009
    We are on City water, and I find it hard to believe that it would change that much so quickly. The first two week long filter life, I am not sure that the arrows were lined up when the filter was installed. Could this be a cause?
    Genius:
  • 1,689 Answers
Hi doug,
the cause of the issue will be water minerals as well as hard water particles
using the filter below will be best for you as it has water softening properties that will last longer.
http://shopping.msn.com/prices/ge-oem-smartwater-refrigerator-water-filter-gswf/itemid965473717/?itemtext=itemname:ge-oem-smartwater-refrigerator-water-filter-gswf
hope this helps.
regards,
voodoo
Posted on Jun 20, 2009
  • marlon john madrid
    marlon john madrid Jun 20, 2009
    that is the least of the cause. city water is potable, but still if you put fermented bean bacteria in it, you will still see a lot of hard water traces.
My frigidaire refrigerator has terrible chemical smell
FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE
Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Feb 18, 2017 | Frigidaire Refrigerators
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
Replacing the Water Filter
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
My temp gauge light came on and they said I was low on antifreeze in the reserve. after 3 weeks it came back on and repair guys said radiator was very low. now they replaced the water pump and said that my...
well while it may have just been a one thing to another issue by the vehicle overheating it is possible that the original problem was the headgasket leaking which in turn caused the problems in the first place . it is even possiblre that you never needed a radiotor but i can not state this for fact , if the original problem with the vehicle was that the radiotor fluid was leaking I would go with the headgasket being the first problem which caused the secondary problems suchh as the pump and radiator
Sep 14, 2009 | 2001 Dodge Grand Caravan
2000 Jeep Grand Cherokee, approximately 127,000 miles. Vehicle is overheating in traffic or alot of stop lights. Temp drops when it receives clean air on the freeway. Battery died last week after being...
has this vehicle got antifreeze in it or are you one of these that lives in the south and never puts any in because it doesnt get cold enough ,same thing here in spain with the stupid english who come to live here ,stand up the bar and reckon they know it all with their la de da accents .Well your problem is caused by a blocked radiator that has gunged up with the rust that occurs inside your engine ,which is caused by no antifreeze to stop the corrosion as for the battery ??well they can last a month or ten years ,buy a bosch battery next time and not a cheepie .Anyway best of british with it and as a not i have just changed a jeep rad ,same model a 99 ,and the plastic **** rad was 600euros here in spain
Sep 02, 2009 | 2000 Jeep Grand Cherokee
Icemaker not working
Ok, if the filter has not been changed in a year or 6 months, i would recommend changing it asap. Now, if this continues to be the issue after the filter change, you will then need to replace the inlet water valve assembly.
May 31, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
