Question about Lexmark Office Equipment & Supplies
Cant download update driver for X3580 error message 1001
Error message says could not load file or assemly ''scrttls.nlp! Need to download update because keep getting error message when starting PC, Message says motitor problems. Running windos WP
Help Please
  • 23 Answers
Try removing the command to startup the lexmark printer monitor from the startup file. Just run "msconfig" and uncheck the command. Then reboot and try the update again.
Posted on Jun 20, 2009
Cant download drver software for lexmark x3580 onto acer aspire one
Try to download and install the X3580 printer driver from the Lexmark website. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
I hope this helps. Thanks.
Nov 09, 2011 | Lexmark X3580 All-In-One InkJet Printer
How to fix mp3 firm ware because it said file system error.
Please visit Coby website:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
From here you can download "MP-610 Firmware Update for File Sys Error". Decompress this .zip file and you can see how to repair your player if you read the pdf document. Finally you should run the .exe file and do all that are described in the document.
Thanks.
gylacz
Sep 14, 2011 | Coby MP-610 MP3 Player
I put some files on my mp3 player. when i go to play them it says format error. however, that isn't my major problem. now my computer keeps telling me to format my mp3, which will wipe my entire memory,...
Files on the MP610 could be in the wrong format or corrupt. For the correct format look in the manual on page 40:
  • cobyusa.com/files/manuals/MP610_MN.pdf
And there's a firmware update for this issue for the MP610, see next site:
  • cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
For the update look under Downloads and select the zip file MP610_firmware_update.zip:
1. Right click "...update.zip"
2. Save Target As... to save the file to a location on your computer
3. Unzip the zip file: an instruction for how to update the LCD firmware
is included in a pdf file.
Hope this solves your problem. Just post a comment in this thread, when needing more help.
Jan 23, 2010 | Coby MP-610 MP3 Player
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Sep 07, 2009 | Office Equipment & Supplies
I try to update tiger woods 09 on my used xbox. It either freezes, or disconnects me from xbox live
If you have tried to update Tiger Woods more than once and it is causing an error then you are going to have to manually update the drivers on your Xbox 360.
You need a to download a list of the $System Update files for the Xbox 360 to your computer. Starting with the oldest update file put them on a USB flash drive one by one. Once you have a file on your USB drive you need to put the USB in your Xbox 360 and then boot it up. If you still get the Update your System message then it wasn't the correct file. Go back to your computer and remove that $System Update file from the USB and load the next one on your USB.
Continue this process until you find the $System Update file that fixes your Xbox freeze.
If you don't know where to find the $System Update files just message me.
Hope this helps. Please Rate me!
Thanks,
Jul 07, 2009 | Microsoft Xbox 360 Console
Intel Graphics Media Accelerator Driver
The file is apart of the Intel graphics driver system. If you uninstall and reinstall the Intel MGA driver it may clear up this message.
You can also try to update the driver using the following method:
Click -START - Control Panel - INTEL GMA Driver
On the driver control screen click on - Information -
Select the - Support - tab
Click on the Graphics Driver downloads Link
Select - Graphics - and follow the prompts
You may be asked to download the update utility, do so
Select the Check System button to get latest driver
This method will keep your computer up to date.
Jan 13, 2009 | HP Compaq Evo D310v PC Desktop
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
Printer Froze and Have Download Message
Downld File Now
RFU LOAD ERROR
RESEND RFU OVER
PARALLEL PORT
Aug 13, 2008 | HP LaserJet 5550 Printer
Lexmark x3580 printer
This doesn't sound like the exact text of an error message... if you can get me an exact quote, that would be helpful. But, the time out period expired sounds like it was failing to communicate with the printer. The first thing to do would be check the cable between the printer and the computer - make sure it's firmly in place on each end. Then, make sure the printer is coming on, and with it on try to install again.
If that doesn't help, please post the exact text of the error message and I will look into it further.
-Dyllan
Dec 18, 2007 | Office Equipment & Supplies
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
