Question about Bose 3 2 1 GSX System
Trying to connect pc to ethernet connection, is there software?
I'm connecting to the nic card and aquiring a address of 169.254.51.254
using a cross over cable, and can ping. Is there software available to log into this machine. I was also tryed hyper terminal and internet explorer.
Thanks, Michael
  • michaelbr220 Jun 20, 2009
    Ekse,
    I have a bose 3-2-1 GSX system, model AV3-2-1H GSX Media center. On the back there is a ethernet (nic) connection. In the user guide it says for future use. What I would like to do is use this ethernet connection to possibly manage the information on the hard drive.
    Thanks, Michael
    What is the ethernet connection in the back used for? I would like to manage the library using my laptop pc if possible.
  • 13,433 Answers
169 is automatically set by windows if I remember correctly when there is no internet connection.
Are you trying to get online. or what are you actually trying to do and could you send me the brand and model.
Please clarify what your attempting to do. You have posted this under BOSE stereo system, which is why I'm confused.
Posted on Jun 20, 2009
  • Ekse Jun 20, 2009
    For future use generally means, not yet used and it has no function, a software / firmware update may give it some functionality in the future.
    Your getting a 169.254.51.254 ip or similar means there is no connectivity and is automatically assigned. I suppose you tried to ping the above ip address which is your own computer and of course you will get a reply.
    I don't see anything relating to connecting it to a computer with the Nico and there seem to be no software available.
    Looked over a few manuals and it wasn't mentioned.
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the...
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
This is for all routers to set up wirelessly.
Aug 23, 2010 | SMC WBR14-N Router
Tip
Limited Connectivity & WiFi issue
make sure there is only 1 pc connected.....
reset the line PPPoA/remove the dsl jack (if PPPoE) for 30 secs > delete all wifi profiles > clear the TCP/IP cache by using "netsh winsock reset" at the command prompt (if vista then from accessories right click on the command prompt and run as administrator) > switch off the router > restart the laptop/PC > remove the ETH cable > restart the router > after all LEDs are back ON > connect the ETH cable (and Enable the LAN connection if disabled) > NIC aquires the IP address > the same goes for the wifi adapter > aquires the IP address.
Hopefully the connections should work now.
on Mar 11, 2010 | Computers & Internet
Linksyswireless-N WRT120N The ethernet ports dont work when connected to my desktop but works on other pc's or my laptop.
If you can use the same cable and ethernet port to connect to the router with a laptop, or other computers, then you have isolated the problem to your non-connecting computer. Plug in the computer with the connection issue with the same ethernet cable. Next, open up command prompt and type in the command "ping 127.0.0.1". This command checks your NIC card to see if it is working properly (if you get "Reply from 127.0.0.1", then your NIC card is good, but if not, then you need to replace your NIC card.). If your NIC card is good, ping your default gateway (i.e. using a linksys with a default IP, type "ping 192.168.1.1" in command prompt) Your router's private IP Address, which can be found by successfully connecting another pc and, on the connected pc, typing "ipconfig" in command prompt, is also known as the default gateway. If you get 4 "Request timed out.", or "Reply from 169.X.X.X" ("X" being any number), then your network connection settings on your pc are incorrect. To fix these settings, assuming that you have DHCP enabled on both your router and the computer being troubleshooted, use the commands "ipconfig /release" and then "ipconfig /renew" in command prompt. Give the computer a minute or two to allow the computer time to acquire a new IP Address, and the correct configuration from your router. Now your computer should be connecting properly.
Feb 20, 2010 | Linksys Wireless-N WRT150N Router
How do i get connected to another local computer with wire
you need either a "crossover" cable or both plugged into an ethernet switch, with network settings the same but i.p. addresses off by 1 digit. eg. 192.168.1.3 on computer "a" and 193.168.1.4 on computer "b".
Oct 25, 2009 | Computers & Internet
Just installed a D-Link DFE 530TX network adadpter into Dell Dimension 5000 desk top. Runnng Windows XP SP3. BT Home Hub 2.0 router. Even though broadband connection is fine to the router. The network...
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Jul 12, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Cannot use model #f5d8233-4v3
If you have their provided cable modem, you would use a crossover ethernet cable to connect the router in between their modem and your PC... First thing power off everything, disconnect the ethernet cable from y our PCs NIC card and plug it into the internet port (usually yellow) on the router, from the routers end, choose a LAN port on the router and connect an ethernet cable in it, then take the other end of the cable you just plugged into the router and plug it into your PCs NIC card... Now within your OS you will have to change the default gateway settings to reflect the routers IP address (user defined IP address) and then you should be set.... Let me know if it works and how else I can help you....
Joshua79
Apr 03, 2009 | Belkin Computers & Internet
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Lan connection
Re-Install the NIC Card Drivers
Enter the TCP/IP address
click on Ok
Restart the system
Jul 29, 2008 | E-Machines eMachines Desktop PC
Can't connect to internet
It sounds like the driver for the USB network device is not loaded correctly. So, you'll need to reinstall it from scratch. Unplug everything, install the software, then reattach the usb cable to the PC.
The other thing is, did you DISABLE the network adapter that was already in your PC when you added the USB network adapter? If not, you need to do that. If they are both active but only one is connected, the system could still be trying to use the other network adapter and tying up the resources in the process.
Jun 23, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
Bose 3 2 1 GSX System Logo
834 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
