Question about Samsung T220HD LCD Monitor
Problem with powering the monitor up. It just flicks off.
My monitor just don´t want to start properly. I can be pushing the powerbutton for 10 mins before the monitor actually is powering up. I´ve had the problem for around 2 months now, and i bought the monitor for roughly a year ago. I´ve used it together with my computer via DVI and i´ve also been watching some TV on it. I think the problem came when i installed windows 7 on my computer instead of vista which i had before. But if its something up with the power suupply, the drivers shouldnt mean very much or am i wrong? I´ve tried to deconnect everything except the power cable and the problem persists. What should i do?
  • chanix Jun 21, 2009
    Thanks for answering! I have no clue about how to take it apart, but i can try tomorrow maybe. I dont have enough time today to investigate the case.
    But this problem is really making me sick. Imagine you hear from a friend that something interesting is showing on TV and you want to check it out as well. You try to power your TV up but don´t succed before that show is over, really annoying.
    Novelist:
  • 159 Answers
The operating system would not stop it from powering on.
It should power on even if disconnected from a computer.
You are probably in need of having the powerboard redone. Possibly a failing inverter.
If you know how to take it apart and can get some pictures to me at bammbamm@ptd.net , I may be able to see the problem.
Posted on Jun 21, 2009
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Emachine E109t6w flashing power button
means it has no signal and/or it is asleep. make sure all your connections are connected properly. if you have unplugged or plugged in the monitor lately make sure you don't have any bent pins on the vga cable.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 12, 2012 | E-Machines eMachines Desktop PC
Fridge part freezes up , lost manual cant work out what the on/of switch is meant to do?
If this was my fridge
1 I would give it a soft kick with my right foot/ your left
2 nothing happens
3 empty the fridge
4 push the off switch
5 should the unbeliveable happen that the frozen part would start to melt
6 then I put some boiling water in a wash basin in the fridge and a few towels on the floor-we don´t want water on the floor, do we?
7 when all the "frozen places" have disapperaed .
8 clean the fridge´s insides
9 push the on button and close the door properly
10 wait for 30 min open again and see if the places that are supposed to be frozen arn´t frozen
11 if they are put the good things back into the fridge
12 and have a good cup of coffee
Good luck
kollagunn
Jun 04, 2011 | Freezers
I have a problem with my fujitsu siemens scaleoview w19-1 monitor. when starting up the monitor, all that happens is a flashing blue light from the powerbutton... black screen and an annoying sound from...
It sounds like it is not getting steady DC voltage, that will be the first place to check.
From the spec, it does not indicate if it has built-in power supply or using the AC adapter. http://www.subincho.com/hardware_review/pdf/fsc_p19-1.pdf
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 05, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
May 21, 2009 | ViewSonic VG2230WM LCD Monitor
The power button flicks on and off and I have checked all my hookups, plugs ins and they all seem to be in working order
If you mean the on light goes dim, then I've had the same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 15, 2009 | Gateway FPD2275W LCD Monitor
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Monitor colour problem
could be loose connection, push-in the video connection and screw the cable to the video port properly.
Jun 03, 2008 | Computers & Internet
Monitor
ferozkhan, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually an economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Apr 25, 2007 | IBM E74 17" CRT Monitor
Samsung T220HD LCD Monitor Logo
383 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
