Question about Xerox CopyCentre C20 Black and White Copier
OPEN HEAT ERROR
My copier won't make any more cpoies an error shows that there is a heating problem can you help?
  • 1 more comment
  • Rick Kasper Nov 28, 2007
    There is no heat lamp in the M20, It is internal to the heat roll.
    The fuser is 99.999999 percent the likely problem.
  • elchuy471091 Feb 07, 2008
    Hi I have the same problem with my Copycentre C-20. Would you please tellme how to reset the code?
    Thanks
  • webcorp99 Sep 24, 2008
    xerox m20 open heat error how to fix it
    Novelist:
  • 208 Answers
Replace the fuser unit.
The heat sleeve in the roller goes bad.
Posted on Nov 28, 2007
    There is no heating lamp in the M20, it is a heater internal to the heat roll.
    The problem WILL be fixed replacing the fuser.
  • 69 Answers
Hi im jules_09,does the machine warms up?if not reset the error code in the program.if the is still there check the termistor,heating lamp and termalfuse one of those components are deffective.test it with a tester
Posted on Nov 03, 2007
  • 239 Answers
On this model, most of the time is a fuser assembly.
However, the correct fuser assembly has to be replaced in this machine model.
If the fuser moducal has been replaced and still the same problem, the main board needs to be replaced.
Just to know ahead of time, be prepared to know the drum unit might have to be replaced if the main board is replaced, due to the fact the drum unit has a Crum chip on it and may need to be replaced at the same time.
If the main board is replaced, make sure the correct main board is replaced for this model machine.
One other idea, if the machine has simms chips on the back remove them and reinsert them back in again. Make sure the machine has been unplugged first.
Good luck.
Posted on Oct 26, 2009
  • 97 Answers
Fuser Unit is faulty.
Posted on Aug 03, 2009
Samsung ML3051N open heat error cycle power
check the fuser assy thermostate , if pressor roller melt then change the fuser assy
Feb 19, 2011 | Samsung ML-3051N Laser Printer
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
On 2/1 and then again on 2/3 we have received an error message " Open Heat Error". At that time the printer would not function. Upon shutting down, and turning back on the message was removed...but this is...
Any heat errors on the dell 1815 means the fuser has gone bad. Your best bet is to replace the fuser, part # UG297. Here is a video that shows you how to replace it. Iteminc.com has these in stock and ships same day (till 7pm est). Hope this helps, Good luck!
Feb 03, 2010 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn error code "open heat error?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 29, 2009 | Dell 1815dn All-In-One Laser Printer
Getting open heat error message, what's the solution
hi i dont know why my printer is showing open heat error i dont understand please solve this problem
Jul 10, 2009 | Dell 1600n All-In-One Laser Printer
Diaplay shows open heat error after one print.
The fuser is overheating. Probably now has blown the overheat thermostat. You have to replace the fuser to get rid of it. Not real hard to do.
Mar 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Open heat error
when i on my scx-4216 samsung laser printer it show on screen open heat error on display screen
tell me the solution
Apr 17, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Xerox CopyCentre C20 Black and White Copier Logo
5,773 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
